Old 08-17-2012, 11:50 PM   #1
Ignition switch/Steering lock question
Hey,
I think my Boxsterīs ignition switch is broken. Itīs very tough to turn to key and difficult to put the key in to ignition switch. And when i take the key, steering lock wonīt lock. If i change mechanical and electrical parts, can i still use my old key??? Or is it possible to clean parts and get it work?
Thx for advises.
riquuu
riquuu is offline   Reply With Quote
Old 08-18-2012, 12:22 AM   #2
Spinnaker's Avatar
Just change the electrical part. Common problem with ignition switch.
Old 08-18-2012, 12:28 AM   #3
Okey I will start with electrical part. -> garage:dance:
Old 08-18-2012, 06:08 AM   #4
doragman's Avatar
just did mine last week -- you will need to cut down a small screw driver (no longer than 3 inches on a small blade screwdriver) to access the 2 set screws -- hardest part of the job ...make sure you get the right part -- there is an "A" and "B" version -- original 986 was a black "4A0 905 849B" later replaced with a white "4B0 905 849B" version -- they are not interchangeable.
I know because I bought the wrong one the first time --- I still have it by the way if you need the black "4A0 905 849B"
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 08-19-2012, 01:30 AM   #5
Problem solved and parts changed. Now itīs working perfectly. The part cost 20 euros and took like 4 hours to open screws!!!
