just did mine last week -- you will need to cut down a small screw driver (no longer than 3 inches on a small blade screwdriver) to access the 2 set screws -- hardest part of the job ...make sure you get the right part -- there is an "A" and "B" version -- original 986 was a black "4A0 905 849B" later replaced with a white "4B0 905 849B" version -- they are not interchangeable.
I know because I bought the wrong one the first time --- I still have it by the way if you need the black "4A0 905 849B"
'99 986 Baton Rouge, LA
