Old 05-10-2012, 10:34 AM   #1
Dash lights
The backlight for my odometer is out. I found a previous thread showing how to change but the info/pica are gone. Can it be done without removing the clustercand steering wheel? Also I get a small "eek" from the engine when I shut it off. Normal?
davedeck is offline   Reply With Quote
Old 05-10-2012, 10:54 AM   #2
Definitely need to remove cluster for bulb changes but not necessarily steering wheel. Take extra care to protect dash as there are some really sharp clips/edges on underside of cluster.
"eek" could be anything...or nothing - need many more details before even remotely begining to diagnose.
Good luck
Old 05-11-2012, 11:05 AM   #3
Yes, you'll have to remove the cluster to replace the backlight bulbs. Its easy, no more than 5 mins max. This tech article has the instructions for removing the cluster:
Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) -
Old 05-11-2012, 03:23 PM   #4
Thanks for the advice!
