Old 05-09-2015, 06:51 AM   #1
I am my own mechanic....
Timco's Avatar
RMS install question.
I replaced this as per Bently.
When my Indy came over to swap the IMS he said man, that looks really deep.
Book said 11mm as I recall. I set it with a depth gauge.
Is this correct? Just him / me? Now I'm reluctant to torque the flywheel bolts.
'08 VW Touareg T-3 wife's car
Old 05-09-2015, 10:19 AM   #2
"Look" vs. your measuring instruments ? I say the instrument wins.
There has been some discussion about the correct depth. One aspect is to let the seal wipe on a slightly different 'ring' around the c/s.
Try asking JFP on Renntech for the geekish details?
Old 05-09-2015, 10:35 AM   #3
flaps10's Avatar
The 11mm is from the crank face and not the crank case. Easy mistake to make. I did.
flaps10 is offline   Reply With Quote
Old 05-09-2015, 11:55 AM   #4
Timco's Avatar
Oh ****************. I did it wrong. Glad I asked!!
Thanks.
Old 05-09-2015, 01:51 PM   #5
For the newer PTFE seal, the correct installed depth is 13 MM measured from the flywheel mating face on the crankshaft. This is where Porsche's $500 installation tool puts it.
Old 05-09-2015, 01:58 PM   #6
RennTech also has the very simple "Home Depot" pvc install tool instructions. Worth using because if the seal goes in canted,it is useless and you'll destroy it when removing it and you will have to reorder -.
Old 05-09-2015, 03:11 PM   #7
Timco's Avatar
I used the bell end of a stick of 3" schedule 40 PVC. Perfect fit.
Good thing I bought two. I'll pull & reset.
Thanks.
Old 05-09-2015, 03:37 PM   #8
Use the bolts also -per RennTech to avoid canting the seal.
