Old 04-24-2012, 08:46 AM   #1
986 five-speed tranny - unmodified Audi 012?
As above, I understand the five-speed transaxle in the 986 is an Audi 012 unit. Most references seem to indicate it's externally identical.
Is it literally identical / off the shelf. Could you use a salvage 012 from, say, an A4 and stick it straight into a Box?
Old 04-24-2012, 09:34 AM   #2
Theoretical propagandist
Eric G's Avatar
The short answer is yes as the A4 and VW Passat have the same transmission with one difference in the gearing of 2nd and 3rd gear. It will bolt up.
Note: If you have taken your transmission off you will see extra bolt holes on the housing. They will fit each of the aforementioned cars.
Old 04-24-2012, 10:00 AM   #3
Gearing lower or higher in the VW Audi version?
Old 04-24-2012, 12:42 PM   #4
Over here, good used Boxster transmissions are only running $400-$500 ea. My Spec Boxster racing friends have 2-3 spares each. When one fails, they just swap in a replacement. Broken units are sold for scrap since it costs more to rebuild (~$1,200) than to replace.
Old 04-24-2012, 12:49 PM   #5
They're probably about £500 here. But you can probably pick up the Audi version for under £100.
Was just wondering. If it's a minor ratio difference - and especially if those ratios were lower - I'd have no problem shoving the Audi unit in. No problem with mine, was just wondering.
Old 04-25-2012, 06:56 AM   #6
Eric G's Avatar
Here is what I have been able to find:
five-speed transaxle or five-speed Tiptronic S dual-function transmission
Gear Ratios (manual)
1st 3.50:1
2nd 2.12:1
3rd 1.43:1
4th 1.03:1
5th 0.79:1
Reverse 3.44:1
Final Drive 3.89:1
Gear Ratios (Tiptronic S)
1st 3.66:1
2nd 2.00:1
3rd 1.41:1
4th 1.00:1
5th 0.74:1
Reverse 4.10:1
Final Drive 4.21:1
ETKA, but it takes a while, even for one specific tranny code - here are just the basic engine/tranny combos for 1999-2000 Passat 4-cylinder TDIs w/ manual trans (MKB = Motor Code, GKB = Tranny Code):
For example, the ELN / ELP transmission (6 speed) lists as:
Final drive: 3.875
1st - 3.50
2nd - 1.889
3rd - 1.231
4th - 0.871
5th - 0.667
6th - 0.561
The five speed EXC / EYZ list as:
Final drive: 3.625
1st - 3.50
2nd - 1.889
3rd - 1.231
4th - 0.871
5th - 0.667
As AUDI lists them:
Trans Type: 5
1st - 3.50
2nd - 1.889
3rd - 1.231
4th - 0.871
5th - 0.667
Old 04-25-2012, 12:38 PM   #7
Thanks, Eric. So taller/longer final drive and taller ratios after first. Not ideal.
Might the petrol models have different ratios or final drive? Higher reving so....?
Old 04-26-2012, 12:21 PM   #8
Opposed to Subie Burble
Overdrive's Avatar
I'm not sure about cars outside of the US, but I believe the ratios for the 5-speed and final gear changed starting in 2000 with the debut of the 2.7. I don't have my proof of that readily available, but I'm pretty sure there were slight differences in the gearing for the 2.5's 5-speed and the 2.7's 5-speed.
I'll see if I can dig it up somewhere and post back here.
-O/D
IMSR + RMS
Robbins glass window top
Old 04-26-2012, 02:02 PM   #9
Originally Posted by pothole View Post
...But you can probably pick up the Audi version for under £100....
Wow that really is cheap!
Old 04-26-2012, 04:03 PM   #10
Well, I haven't checked, but you can certain pick up a five speed BMW manual box from that era at a breakers/salvage yard for about that much. They sold billions of A4s/Passats, so I would expect a glut of supply - especially given most people would just scrap a late 90s Passat these days if the gearbox failed. Can't see there being any demand for the things.
Old 04-26-2012, 04:05 PM   #11
Yes, the 2.7 has longer gearing here, too. But then it's a bigger, torquier engine.
It probably explains why subjectively the 2.7 doesn't really feel much quickerm in any given gear.
Old 06-14-2012, 03:29 PM   #12
Topless's Avatar
Hmmm, The Audi A4 and Passat had top speeds of about 130mph with a 25" diameter wheel. Those might be ideal gearboxes for a swap if you want to maximize torque and don't mind a higher fwy rpm.
Old 06-14-2012, 06:01 PM   #13
Hmmm, The Audi A4 and Passat had top speeds of about 130mph...
with a 25" diameter wheel....!
Like the ones you see in Santa Ana..?
Old 06-14-2012, 09:58 PM   #14
Topless's Avatar
Naw, The standard diameter of a wheel/tire combo is the same on a Boxster/Audi A4... 25" total diameter.
Old 05-27-2013, 11:50 AM   #15
Bad pinion bearing on a 6 speed gearbox..?
It seems that the pinion bearing on my 6 speed tranny is failing (the differential has excessive noise when you unload it at low speed), a friend that specializes on P cars told me that you need a press with 40,000lbs capacity (..!) to replace the bearing...
I am planning to remove the pinion shaft, by any chance do you know where can I take it to get the bearing replaced?
Old 05-27-2013, 12:30 PM   #16
Topless's Avatar
Check with 911 Design in Montclair- Loren Beggs. If he doesn't do it, he will know who does. Replacing the pinion bearing is neither easy or cheap as I recall. For me, a replacement trans was cheaper.
911design - Porsche service, maintenance and repair
