Old 05-27-2013, 12:30 PM   #16
Topless
Track rat
Topless's Avatar
It seems that the pinion bearing on my 6 speed tranny is failing (the differential has excessive noise when you unload it at low speed), a friend that specializes on P cars told me that you need a press with 40,000lbs capacity (..!) to replace the bearing...
I am planning to remove the pinion shaft, by any chance do you know where can I take it to get the bearing replaced?
Check with 911 Design in Montclair- Loren Beggs. If he doesn't do it, he will know who does. Replacing the pinion bearing is neither easy or cheap as I recall. For me, a replacement trans was cheaper.
911design - Porsche service, maintenance and repair
