Old 04-21-2012, 07:25 AM   #1
Zimmerman coated rotors - any prep?
Do these rotors need any prep before instaling them? Does the coating need to be scuffed off the actual rotor surfaces, or will it wear off normally during usage?.
'99 black 986
Old 04-21-2012, 07:37 AM   #2
Coating will wear off when you brake...
Old 04-21-2012, 11:54 AM   #3
Ex Esso kid
If they didn't arrive painted, consider painting the rotor hats before installation.
Old 04-21-2012, 01:41 PM   #4
Why paint the hats?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-21-2012, 01:50 PM   #5
Something you don't see in Miami - Rust.
Old 04-21-2012, 02:24 PM   #6
I thought the point of buying rotors with coated hats and edges was that they would not need to be painted.
'99 black 986
Old 04-21-2012, 03:33 PM   #7
Ex Esso kid
If you are fussy about your car looks, a painted rotor hat looks way cooler behind a detailed wheel, it also protects against rust which I now know happens plenty in places other than NY like Florida beach areas.
Old 04-22-2012, 07:15 AM   #8
Coating will wear off in a year (speaking from experience) from heat on the rotors, only the OEM rotor hat don't rust because it's painted.
Old 04-22-2012, 08:56 AM   #9
Johnny Danger's Avatar
I thought that Zimmerman was in jail ?? He's already out selling rotors ??
Old 04-23-2012, 08:35 AM   #10
manolo's Avatar
Yep, they're built in the same factory as Casey Anthony's IMS bearings...
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 04-25-2012, 06:42 PM   #11
Couper1's Avatar
Installed my Zimmerman rotors about 5 years ago. they came with the hats pianted a glossy black. I didn't care for that look and questioned them. they said that paint woul last a long time with no rust. here it is 5 years later and they still look as good as the day I instaed them.
Couper1 is offline   Reply With Quote
Old 04-29-2012, 01:24 AM   #12
Red face
I have had them for a year now, no rust and no prep. they are a very good quality product in my humble opinion. You are talking about the Z- coated ones i presume.
I have the drilled ones , they look great and work just as well.
Marchie is offline   Reply With Quote
Old 04-29-2012, 09:16 AM   #13
I have the Zimmerman drilled rotors. I painted all of the hats silver with high temp paint because the rears were not available coated and I wanted them to match.
And, yes, the coating will be scuffed off of the rotor surface on your first braking.
Cheers
mark
Appleguy is offline   Reply With Quote
Old 04-30-2012, 12:48 PM   #14
zimmermans
Hi, they make the rears Z coated and drilled as well, got mine off Pelican parts
Old 04-30-2012, 12:54 PM   #15
Its always a good practice to do a quick wipe down of the rotor surface with brake cleaner prior to installation.
Old 04-30-2012, 05:36 PM   #16
jsceash's Avatar
I've had the Zimmerman drilled and slotted rotors for two years the hats are still as silver as they were when installed. No rust. My guess is they will wear out before they rust.
