Old 06-27-2006, 06:18 PM   #3
Send a message via MSN to jscrimsh Send a message via Yahoo to jscrimsh
Originally Posted by deliriousga
Finally, I fiddled around and found the sensor and replaced it and all is good.
Which sensor did you replace? Was it the Coolant sensor found on the bottom drivers side of the engine? I have the same issue and believe its the sensor, but want to make sure before I spend money for parts that have to be ordered...
Do you happen to have an OEM part number as well? When I checked a few parts places, they couldn't do anything without the OEM number.. A few others had the coolant sensor for anywhere from $14-$25. If that's the right sensor, then I figure that's and easy enough thing to do
jscrimsh is offline   Reply With Quote
