Old 03-19-2012, 08:35 PM   #1
midlifechrisis
Drphil's Avatar
bad idle following battery disconnect/reconnect
I replaced my steering lock mechanism, as the old one went bad.
Upon reconnecting the battery it did not want to idle smooth. It was up and down, close to killing with out keeping on the pedal some.
Will this straighten out? Is it a normal occurrence ? I've looked thru many threads on this procedure and thru my manual but don't see much. Seems before doing this I had seen someone say that the a brain had to re set or re-learn for a while. Is this true?
Everything else that was bad is now fine, no more sticky key , electronic locks working now,
Anything I should check or test.
Drphil is offline   Reply With Quote
Old 03-20-2012, 01:03 AM   #2
Steve Tinker's Avatar
Try this...
Disconnect the battery again.
Touch the positive (+) cable to the chassis for a few second to discharge any capacitance in the system.
Reconnect the battery and switch on the ignition - but do not start the engine - leave ignition on for at least one minute.
Switch off ignition for at least 10 seconds.
Restart engine.
It may take several miles and about 3 - 4 heat cycles of the engine temperature to completely reconfigure the system.....
2001 MV Agusta F4.
Old 03-20-2012, 04:18 AM   #3
midlifechrisis
Drphil's Avatar
Originally Posted by Steve Tinker View Post
Try this...
Restart engine.
Steve,
Thanks for the advice, worked like a charm! running grreat this morning, everything seems to be reset
and the ignition is perfect. that was why i had it disconnected, to replace the lock assembly and switch.
Old 03-20-2012, 07:20 AM   #4
jdiba's Avatar
Where else are u gonna get this type of knowledge ?.........I ask you.
-May all the roads you travel in life be Speed Trap free.
01 986 Boxster S. Arctic Silver. 6 speed manual. IMSR/RMS.
jdiba is offline   Reply With Quote
Old 03-23-2012, 05:13 PM   #5
Porsche "Purist"
Paul's Avatar
Don't forget to program the windows too. Roll them up. Let go of the switches, then push and hold in the up position for 5 seconds.
1987 924S. 2002 996TT. PST-2
Old 05-02-2012, 03:06 AM   #6
landrovered's Avatar
Sniphaj is a spambot
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
