02-19-2012, 01:43 PM
Oil Pressure
What oil pressure should you get in a 2.7 Boxster. I installed an accusump. As part of the kit I added a pressure gauge. It is in a fittinng on the outlet side of the oil filter. I took a 20 mile spin to watch the pressure and get an idea what would be normal. It's all over the place 25-75. I had expected a fairly stable 50 to 60 PSI.
02-19-2012, 02:14 PM
It can range from 100psi at cold start down to 10-15psi when hot.
02-19-2012, 02:32 PM
Maybe that's why they don't put oil pressure gauges in them form new.
02-19-2012, 08:49 PM
jsceash...
Just think about it - you have oil pump(s) fixed & mechanically connected to the engine crank / cams - the higher the revs, the greater the pressure and flow - up to the factory set oil pump blow off point.
What you are seeing is 25 (I assume pounds per square inch) @ idle and 75 @ +4000 rpm.
The only other variables are the engine oil temperature (thicker when cold = higher pressure) and oil viscosity, 5W30 grade oil has a higher flowrate but lower pressure than (say) 20W50 grade @ normal operating temperatures.....
2001 MV Agusta F4.
02-20-2012, 09:22 AM
Yes, oil pressure is RPM dependant (and temperature). IIRC the generally recommended minimum is ~10 Psi per 1,000 RPM, Hot.
09-26-2016, 07:53 AM
Bumping this old thread, now that you have had this gauge installed for a while, have you ever recorded it, or captured it in frame, while you were driving on the track?
Since you are taking the pressure reading at the oil filter sandwich adapter I expect you are seeing it around 10-12 PSI higher than what I see, since I pick up the oil pressure at the stock oil pressure switch location at the front side of the right valve cover. Once I get the car good and warmed up on track, I see around 40-45 PSI there when I am at steady state driving with the oil around 210-220F. I am guessing that you see between 50-55 PSI unless you are at low revs? And in that case it is rising and falling. When the car is cold mine is pegged at around 60-65, hard to tell since the lines on the gauge are very close together at the top of the range.
If you have interior video footage that captures the gauge, I would love to see it.
Steve
