jsceash...
Just think about it - you have oil pump(s) fixed & mechanically connected to the engine crank / cams - the higher the revs, the greater the pressure and flow - up to the factory set oil pump blow off point.
What you are seeing is 25 (I assume pounds per square inch) @ idle and 75 @ +4000 rpm.
The only other variables are the engine oil temperature (thicker when cold = higher pressure) and oil viscosity, 5W30 grade oil has a higher flowrate but lower pressure than (say) 20W50 grade @ normal operating temperatures.....
2001 MV Agusta F4.
