Old 01-15-2012, 09:29 AM   #1
Secondary Sir System - Fail status
Gents,
Durametric is showing Pass for 4 out of 5 under Ready Status. Secondary Air System is a Fail. Read and reread a lot of threads and followed quite a few troubleshooting steps. Checked air leak with a propane torch and didn't see any jump in RPM. Did this on the upper side on the engine in all nooks and crannies. I had a Cyl 6 misfire earlier and swapped 6 coil to 5 and cleared the code and haven't seen it since.
I ran the capture of Actual Values for various systems but am not sure what to compare it against. My O2 and cat check out fine under ready status but I understand that don't mean there isn't an issue related to the above title.
I did Activations using Durametic. I'm able to start and stop the items in the picture below except the 'Electrical switch-over valve Secondary pump'. I hear a click-click but don't hear a fan. Should there be an actual fan running? The 'Secondary air pump' runs pretty loud so I'm wondering if the Electrical switch-over... should run similar. This issue is really got me stumped. Thanks for your help.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 01-15-2012, 07:55 PM   #2
Crazy Austrian
harryrcb's Avatar
the secondary switch over valve is just a soulenoid type valve and that is the clicking noise you hear, the pump does not activate at the same time in durametrics. you have a second command line to activate the pump seperately.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 01-16-2012, 05:41 AM   #3
So, it can be checked off as working fine? Since the error is specifically pointing to Secondary Air System, the other area would be Air Leak correct? I tried the propane torch method and came up with nothing. What else could be causing this?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 01-16-2012, 07:27 PM   #4
Crazy Austrian
harryrcb's Avatar
what was the specific code you are getting? code-number
Crazy Austrian 007
Old 01-17-2012, 06:57 AM   #5
When i test drove it it gave me a P0507 and also under 'Ready Status' the Secondary Air system was showing a FAIL status. I cleared it and haven't drove it again as I'm concerned I might be doing some damage somewhere.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
