Originally Posted by harryrcb
the secondary switch over valve is just a soulenoid type valve and that is the clicking noise you hear, the pump does not activate at the same time in durametrics. you have a second command line to activate the pump seperately.
So, it can be checked off as working fine? Since the error is specifically pointing to Secondary Air System, the other area would be Air Leak correct? I tried the propane torch method and came up with nothing. What else could be causing this?
