Originally Posted by Bala
I did Activations using Durametic. I'm able to start and stop the items in the picture below except the 'Electrical switch-over valve Secondary pump'. I hear a click-click but don't hear a fan. Should there be an actual fan running? The 'Secondary air pump' runs pretty loud so I'm wondering if the Electrical switch-over... should run similar. This issue is really got me stumped. Thanks for your help.
the secondary switch over valve is just a soulenoid type valve and that is the clicking noise you hear, the pump does not activate at the same time in durametrics. you have a second command line to activate the pump seperately.
