Old 01-14-2012, 12:37 PM   #1
jaykay's Avatar
Short Snork
For those with the stock air box behold the jaykay short snork:
986 00S
Old 01-14-2012, 12:43 PM   #2
jaykay's Avatar
and here...
It will help reduce some the intake flow losses if you are de-snorked. The sharp edge on the air box can really reduce flow efficiency!
I am still shaping it and need a wierd router shape to finish it!
986 00S
Old 03-10-2013, 06:47 PM   #3
jaykay's Avatar
Here it is further shaped! I will test it this spring..
986 00S
Old 03-10-2013, 06:59 PM   #4
Jaak's Avatar
Nice ... I also removed the resonator box (wrench actually did it when installing the rebuilt engine) and it sounds and moves nicely ... :dance:
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 04-03-2013, 06:57 AM   #5
jaykay's Avatar
Thanks.......... a lot plastic weld and Dremel shaping.
This is much better than the air slamming into the side of the airbox!
986 00S
Old 04-03-2013, 08:32 AM   #6
1999 base
Meir's Avatar
beside the theory (that sound correct), do you feel any differences between the full desnork to the "midget" snork?
Old 04-03-2013, 11:42 AM   #7
jaykay's Avatar
My car is still in hibernation....it's still salty and very cold here
I will try it out and let you know my impressions. I am not expecting any noticeable change other than acoustics
986 00S
Old 06-07-2014, 12:14 AM   #8
jaykay's Avatar
Short Snorkle
Sooo when you de-snorkel for that wonderful intake sound you get this:
The air is running into the air box wall and then having to flow over a sharp edge. I just could not stand it! So I took the snorkel and massaged it a little. Notice the difference in flow areas before and after:
The short snorkel installed looks like this:
Buttoned up and ready for a night test:
So far so good! The nice intake sound is maintained and perhaps a little nicer, while getting rid of the sharp edged entrance to the air box. Throttle response seems a tad crisper but of course this is biased placebo effect comment. There seems to be less of retort/stumble from the air box when I stab the throttle at idle
986 00S
Old 06-08-2014, 03:50 PM   #9
Short snorkel: That's what she said! Doh!
Old 06-09-2014, 05:44 AM   #10
jaykay's Avatar
Jeeeez I feel for you buddy. Good luck!
986 00S
Old 06-09-2014, 06:25 AM   #11
Top_Ramen's Avatar
very nice idea and execution. While you have the snork out, what's the diameter on it?
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 06-09-2014, 11:57 AM   #12
jaykay's Avatar
thank you. I will try and measure the major and minor diameter when I have the thing out again. Rightly or wrongly I tried to go with the largest reasonable snorkel opening that could be accommodated in there.
IIRC there is another small snorkel opening just past the air box filter (986) and the strategy was to be larger than that...rightly or wrongly
986 00S
Old 06-09-2014, 08:20 PM   #13
Top_Ramen's Avatar
I'm planning on doing something similar and need to figure out what size velocity stack to get.
Old 06-09-2014, 09:40 PM   #14
The Radium King's Avatar
could you just cut the back out of the airbox so that it is the same size as the opening in the side of the car ...
Old 06-10-2014, 01:35 PM   #15
jaykay's Avatar
IIRC it would be difficult as the inside snorkel appeared to a moulded protrusion on the inside wall of the air box you would end up with another sharp edge unless you fit a nice velocity stack in there....as I remember it there is lots of room under the filter so it can be round rather than elliptical...in order to get the "right" area......it was dark and a long time ago though
986 00S
Old 06-10-2014, 01:46 PM   #16
jaykay's Avatar
Hmmm yes went down that road.....if you are after the biggest area it will end up being elliptical, unless you open or remove the side vent tunnel. This biggest area, as I am close to, may not be optimal....so you may get away with a nice round spun velocity stack and have good flow characteristics.....but then there is the problem of adapting the round to the elliptical air box opening
986 00S
Old 06-10-2014, 07:44 PM   #17
Keep your day job
