11-17-2011, 05:38 PM
#21
Originally Posted by ABQautoxer
So how did you deal with changing the brake bias by installing larger diameter front rotors?
I beg your pardon?
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
11-18-2011, 05:20 AM
#22
I believe he's referring to the fact that increasing the front braking power, without also increasing the rear, will change the brake bias ratio toward the front. Luckily, it's probably a small shift, in the benign direction of front-heavy bias.
11-18-2011, 05:55 AM
#23
double post
11-20-2011, 08:38 AM
#24
Very well. Kindly thank you for the clarification.
11-20-2011, 08:47 AM
#25
Throughout the week parts arrived in time for me to have the GiroDisc's installed on Friday. Without further ado.
GiroDisc Front + Rear Stainless Steel Brake Lines
Thursday's delivery compliments of Suncoast Porsche in Sarasota, FL.
997 GT3 Brake Duct Spoilers
Special thank you to Road Sport Supply/Stuttgart Performance, namely Bryan for the apparel, hat + stickers!
Group shot of the parts being installed (GiroDisc 340mm Two Piece Floating Rotors, 997 GT3 Brake Duct Spoilers, GiroDisc Stainless Steel Brake Lines, + factory OEM brake pads.
Stay tuned for more!
11-20-2011, 08:58 AM
#26
Opposed to Subie Burble
Very nice, parts look great, and GT3 ducts can't hurt, either.
So where's that RSS sticker going? Wind deflector?
-O/D
IMSR + RMS
Robbins glass window top
11-21-2011, 07:12 PM
#27
Update
November 18, 2011 - Location: German Performance Options
Vehicle - 2003 Porsche Boxster S
Parts - GiroDisc 340mm Two Piece Floating Rotorm, 997 GT3 Brake Duct Spoilers, GiroDisc Stainless Steel Brake Lines, + factory OEM brake pads.
As the title states, I pulled the trigger on a front set of GiroDisc rotors for my '03 S. Scaling in at 340mm (10mm shy of the 996 GT3) versus the factory 317 OEM rotors. They are larger and lighter, advantageous. In correspondence with the rotors, I opted for stainless steel brake lines + 997 GT3 brake duct spoilers as well. The installation occurred this past Friday at my local shop, German Performance Options in Nashville, TN. For the better part of 3 years, they have squared me away from general maintenance intervals to my KW V3's + AASCO LWFW. In sum, top notch. Good work, solid work. Onto the installation.
11-21-2011, 07:14 PM
#28
Part 2
11-22-2011, 04:16 AM
#29
Excellent! Fills up the wheel gap nicely!!!
11-22-2011, 06:40 AM
#30
www.klisstle.com
+1
I know it is about performance, but damn, it looks good!
03-30-2013, 11:14 AM
#31
Did you ever end up weighing them vs. the stock rotors?
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
04-02-2013, 05:36 AM
#32
Carnut
2.6 lbs. first post, first paragraph
Cartel, any updates?
'14 Boxster
Thread Tools |
Display Modes |
Linear Mode
