Old 11-02-2011, 07:44 AM   #1
Horn Failure
Hi there
Horn hasnt worked since i got this 99 2.5l, have checked fuse, is fine, when i press steering wheel i can hear a click, i can even hear a click at fuse box
Anyone know what else to check before i go strip front end to get to horn???
McQuaid is offline   Reply With Quote
Old 11-02-2011, 08:52 AM   #2
Registered Boxster abuser
healthservices's Avatar
doubt the relay is bad but you can check that. Removing the bumper is not hard and you should do it every once in a while to clean out the junk stuck in the radiators. be sure to move the condenser out of the way to clean behind it as well.
Yep, there is a ton of sand in there.
Old 11-02-2011, 09:03 AM   #3
Wow, looks like that may be worth doing....not a big job to do????
Old 11-02-2011, 09:09 AM   #4
Nope I'm sure I got my bumper off in less than 15 minutes.
Old 11-02-2011, 09:54 AM   #5
97 Boxster's Avatar
Directions on how to do this?? Are they listed somewhere? I would like to try this as well and my search function is pulling up an advertisement box. Thanks
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 11-02-2011, 10:34 AM   #6
go to youtube and enter 'bumper removal boxster' in the search engine
Old 11-02-2011, 11:32 AM   #7
wow....very easy
Porsche 996 986 bumper removal - YouTube
there's a job for me tomorrow
Just a once off, where is relay box???
Old 11-03-2011, 06:30 AM   #8
Glad i did that, but, cant see a problem with horns, what should i be looking for down by the horns in terms of a fault?
Old 11-03-2011, 07:28 AM   #9
Get a test light or a VOM and test the leads at the horn (remove from horn) to see if you are getting power and ground at the horn when the horn is press.
I had a shorted horn on mine and it was causing the fuse to blow.
I just removed the leads to that horn as the other horn worked and did not blow fuses
You can also test each horn by momentarily applying power and ground to each horn.
Old 11-04-2011, 02:20 PM   #10
The horn also stops working if the ground wire breaks behind the air bag. That's what happened to me.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 11-04-2011, 02:33 PM   #11
OP can hear relay clicking which indicates electric components, including frame/bracket behind airbag, are intact inside and working properly. As such, next most typical issue is actual horns are bad. This is a very common failure b/c the way the trumpet is aimed. It's prone to ingest water / salt / road grime etc. causing internal failure. Once bumper skin is removed and leads/horns are tested individually, cause will be readily apparent but my experience says horns themselves are shot.
Typically, b/c there are twin horns, one fails and the owner doesn't readily notice other than horn may not seem as loud as it used to. However, they do take note (pardon the pun) when second fails.
Good luck
Old 11-08-2011, 02:23 AM   #12
So, had the car up on the ramp this morning to do the oil change, i decided while it was draining to have another quick look at the horn issue, i had a horn lying around workshop and unplugged porsche horn and plugged this in, it immediately sounded, and won't turn off, seems if i put a functioning horn in, its stuck on, can see why old horns blew now
Anyone any ideas??
Old 11-08-2011, 07:17 AM   #13
most common cause is bushings in bracket behind steering wheel airbag are bad allowing contact at all times. However, I thought you stated earlier you could hear relay click on when pushed?
Regardless, test steering wheel bracket by connecting up good horn and either manually pull out on airbag assembly or jamb some cardboard or rags around the edges (stopping frame contact) for it to stop. If it does, issue is common bracket failure. Instead of having to dig in twice on physical horn, replace w/ your temp one (or another one) and just pull horn fuse until you can R&R bracket. For the bracket R&R, either replace entirely ($50-65 IIRC) or repair bushings (< $7 w/ Permatex blue silicone). See this link for R&R links/more details.
If the horn doesn't stop when temporarily pulling on airbag assembly, you may have a short somewhere else but I suspect bracket is cause...
Good luck
Old 11-08-2011, 07:41 AM   #14
So, since looking earlier, i had a mate help with playing with the airbag end of things while i held a working horn on, turns out if you play with the airbag piece then you can get the horn to turn off etc
So looks like i need those bushings, and 2 new horns by the looks of it?????
Old 11-08-2011, 07:50 AM   #15
Also, have you got a link to what these bushings look like??
Old 11-08-2011, 08:08 AM   #16
Indeed but you can't buy just the bushings, need to either repair for <$7 (very easy just follow DIY instructions in various links) or replace entire bracket for > $50. FWIW, the process will be identical (except add in drying time for silicone bushing repair).
See links in the link I posted above. More pictures than you could ever need...
In the mean time, pull fuse B3 (IIRC but check your fuse guide inside fuse panel door) if you replace horns but haven't yet repaired bushings in bracket.
Good luck
