Thread: Horn Failure
Old 11-08-2011, 08:08 AM   #16
Burg Boxster
Originally Posted by McQuaid View Post
So, since looking earlier, i had a mate help with playing with the airbag end of things while i held a working horn on, turns out if you play with the airbag piece then you can get the horn to turn off etc
So looks like i need those bushings, and 2 new horns by the looks of it?????
Indeed but you can't buy just the bushings, need to either repair for <$7 (very easy just follow DIY instructions in various links) or replace entire bracket for > $50. FWIW, the process will be identical (except add in drying time for silicone bushing repair).
Also, have you got a link to what these bushings look like??
See links in the link I posted above. More pictures than you could ever need...
In the mean time, pull fuse B3 (IIRC but check your fuse guide inside fuse panel door) if you replace horns but haven't yet repaired bushings in bracket.
Good luck
