Old 10-10-2011, 07:01 AM   #1
the manual release and remote release use 2 different cables on the latch. Pull the latch cover off in the trunk (2 philips screws, IIRC) and you'll likely see one silver cable has frayed (with the eyelet still hanging on the actuator arm)...
So, you can either replace the entire cable (or you might have to replace the whole actuator if cable not separately replaceable), or you can use an electrical stranded wire connector/grounding lug to make a new (more sturdy) connection to the arm. Depending on size of lug (you want a small one), you may need to shorten the wire a bit more (or fold it over when inserting into lug to tighten). Take the eyelet w/ you to any hardware store so you get one that will fit over the arm.
or or
Or you could really cheat and just crimp it to the parallel manual wire. However, I recommend strongly against this b/c if the manual wire ever frays, you'll be royally screwed for getting in there to fix...
Good luck
Old 10-10-2011, 02:45 PM   #2
keysguy's Avatar
Thanks that was it, the cable is broke I haven't dug to deep into this yet. Does anyone have a blow up of this area or a blow up of the part and what it will take to get at it?
Thanks,
Greg
1979 911 Targa SOLD!!!!
1985.5 944 SOLD!!!!
2000 Boxster
keysguy is offline   Reply With Quote
Old 10-10-2011, 03:32 PM   #3
keysguy's Avatar
OK short update:
I "think" the part I need is 986-512-117-00-M100. It appears that there are conflicting instructions some places state this is for 2001 -2004 others state 97-2004 so I'm kind of lost until I pull things apart and see exactly what is in there. I found a parts blow up. Before I dig to far and take apart more then I may need to does anyone have any words of wisdom from previous experiences with this repair?
Bonez
1985.5 944 SOLD!!!!
2000 Boxster
Tags
rear trunk , remote access to trunk
