Old 06-23-2011, 06:13 PM   #1
Carnut
AndyA6's Avatar
Thumbs up Bypass pipes installed! Now a problem?
Mods so far:-
UD pulley from RSS
Technotorque
Bypass pipes from Fabspeed
First the good news! Awesome sound and most def better performance!!!
Sound, deeper at idle and louder/meaner in the higher revs. no drone. At the same time not annoyingly loud, IMHO just right.
Power, def more. Before the mods I always felt a flatspot between 3 to 4,000 rpm. Now gone, very nice! Engine feels "lighter" if you can imagine that.
Installation was relatively easy, car on lift and the right tools did the job.
Also, wierd enough, the 3200 vibration is gone but I feel some at approximate 3500. Go figure! Somebody posted here that the 3200 vibe was gone as well after he installed the pipes.
Now a couple of points which are not so good.
First after 24 miles of driving the check engine light came on. Why?? Do I have to reset the ECU??
Have to check the exhaust alignment, I think one the pipes touches something.
Any comments and/or feedback please?
Thanks for reading!
Later,
Andy
'14 Boxster
Old 06-23-2011, 07:01 PM   #2
JAAY's Avatar
BYPASS Pipes = you just bypassed your secondary catalytics and now your 02 sensors know it and are throwing the code. You can buy 02 extenders or have the ecu reflashed with a ROW flash.
I hope this helps.
Jay
Old 06-24-2011, 05:10 AM   #3
ddb
www.klisstle.com
ddb's Avatar
Jay
Jay,
How do the O2 sensors/DME detect this downstream change?
Thanks,
ddb
Old 06-24-2011, 05:26 AM   #4
JAAY's Avatar
The dme detects that there gone by reading the difference from the first set of o2s to the second set. The first set was pre cat and the second set is post cat.
Old 06-24-2011, 06:00 AM   #5
Allen K. Littlefield's Avatar
Interesting. When I installed my secondary cat delete pipes I have had no issues with CE lights. There is a O2 sensor fore and immediately aft of my primary cat. There are NO sensors around the secondary. I have passed NYS emissions with no problems for two years now and have never had a CE light come on. I have an '02 2.7 model. Keep us posted on what you find that is triggering the light.
AKL
Old 06-24-2011, 06:05 AM   #6
AndyA6... you have the bypass pipes on an '04 right? The o2 sensors are on the primary cats. Adding the bypass (secondary cat delete) pipes does not effect the operation of the o2 sensors. Go by a cheap, $50 code scanner and see what comes up. I always clear the code and ignore it the first time. If it comes back, then I will see about doing something. Actually, I have cleared a code for an “aging o2 sensor” about 5 times now. I probably should do something about it.
Todd
tamarsha is offline   Reply With Quote
Old 06-24-2011, 06:16 AM   #7
JAAY's Avatar
Ahhhhh. Didn't realize you had a newer box. There correct. It should not affect you. Nmay e time for new sensors or and a maf
Old 06-24-2011, 06:25 AM   #8
ddb
www.klisstle.com
ddb's Avatar
Originally Posted by AndyA6
Mods so far:-
UD pulley from RSS
Technotorque
Andy,
How long has the Technotorque been installed? If it is a recent addition maybe there is a leak in the system and a clamp or coupling needs to be adjusted or tightened.
ddb
Old 06-24-2011, 07:08 AM   #9
Carnut
AndyA6's Avatar
Thanks guys!
Correct, there are no sensors. Either there might be a leak between the headers and the pipes or something came loose in the intake area...... who knows.
I will scan the car asap and see what code(s) there are. The TT is in for quiet a while now.
Whilst driving this morning to work I can def feel more power. Sound is very different now, deeper and a bit louder, me likey!
Also, carefully checked the dreaded 3200 rpm vibration, guess what, gone! As stated in my earlier post I felt some vibs at 3500 but today only (flat6) smoothness, like it should be.
Reporting back asap!
'14 Boxster
Old 06-24-2011, 05:51 PM   #10
I hope this helps.
Jay
Ummm no. The pre-cat O2s are in the headers, as are the post-cat O2s. The secondary cats have no O2s behind them.
There is absolutely no reason you should throw a CEL from removing the secondary cars.
Boxster S
Old 06-24-2011, 06:19 PM   #11
JAAY's Avatar
Hey cloudsurfer. Ummmm Read all the posts!
Old 06-27-2011, 11:36 AM   #12
Carnut
AndyA6's Avatar
OK, scanned the car over lunch break at Autozone.
All 4 Oxygene sensors show a code...... cleared/erased. After 2 miles check engine light back on.
Hmmm, unusual to have all 4 sensors show a code?!?
Any ideas?
'14 Boxster
Old 09-22-2011, 09:31 PM   #13
DenverSteve's Avatar
It's interesting when these threads just stop. Did you find the problem? What was the fix? I'm going to change my exhaust also and agree that your exhaust change alone shouldn't cause the stated problem.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 09-23-2011, 04:31 AM   #14
I deleted the secondary cats years ago and have never had a CEL...something else is the problem.
I know this is an old thread, but perhaps the info will help someone else.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 09-23-2011, 09:34 AM   #15
DS,
Agree, it would be nice when people find solutions to post the results so others can benefit.
Another pet peeve I have when people say that the DME set some codes and never state what the codes are. On AndyA6's last post, codes can be set for all O2 sensors depending on the problem and DME version although only one O2 sensor could be the problem.
Regards,
paul...
paulv is offline   Reply With Quote
Old 09-23-2011, 05:12 PM   #16
Carnut
AndyA6's Avatar
Originally Posted by paulv View Post
DS,
Regards,
paul...
Steve/Paul, I agree! Sorry it took me so long. First of all I finally bought a Durametric cable, an extra laptop and started scanning.
Here are the codes:-
P0036:
Porsche fault code 373 - Oxygen sensor heater behind cat. conv. bank 1
P0056:
Porsche fault code 374 - Oxygen sensor heater behind cat. conv. bank 2
P0141:
Porsche fault code 14 - Oxygen sensor heater behind cat. conv. bank 1
P0161:
Porsche fault code 4 - Oxygen sensor heater behind cat. conv. bank 2
After erasing the codes come back almost immediately.
One theory is that during the pipe install some wiring came loose? I believe that is almost impossible, I watched/helped to do the install.
I also had no chance to get under the car, I totally injured my back and could hardly wallk for the past 2 weeks....... just getting back onto my feet! That did not prevent me to install my 997 shifter, trust me, can be done sitting down
However, I just now scanned again, same codes, same CL coming back after a couple of miles.
Well, there you go!
Later,
Andy
'14 Boxster
Old 09-26-2011, 08:50 PM   #17
Porsche "Purist"
Paul's Avatar
Have you checked your fuses?
1987 924S. 2002 996TT. PST-2
Old 09-27-2011, 07:25 PM   #18
Carnut
AndyA6's Avatar
The fuses are ok. Are there any additional fuses besides the ones in the car I have to check?
TIA!
'14 Boxster
Old 09-28-2011, 07:04 AM   #19
i had this happen once. it was a single bad O2 sensor & it caused codes to trip for all 4......
insite
'99 Boxster
3.4L Conversion
Old 09-28-2011, 02:27 PM   #20
Carnut
AndyA6's Avatar
Thanks Insite!
Friday morning I'll be at the dealership, my friend there will hook the car up and do some "live" logging, we will go from there and see what is going on.
Hopefully this will be resolved soon, I hate to drive around with a CEL although the engine runs nice...
'14 Boxster
