Old 06-13-2011, 04:10 AM   #3
Originally Posted by insite
if you're replacing & not reusing the tubes, just use a short pry bar to get the old ones out. very easy.
this CAN be done w/ the spark plugs installed. if it were me, i'd go ahead & replace the plugs at the same time since i'm already there.....
Just did the plugs and didn't notice the tube was leaking! I guess i can't visualize how to use the pry bar. So do I just put the pry bar in the tube, wedge it against the side of the tube and pull out?
