Old 06-06-2011, 07:50 PM   #1
Bits of plastic in oil filter. Pics Attached. IMS failure imminent? Help!
Changed my oil on a 2001 Boxster 2.7L 57k miles. This is what I found...Translucent brown plastic pieces and black pieces in my oil filter..
Any ideas on what causes this? Thanks!
bkc888 is offline   Reply With Quote
Old 06-07-2011, 06:53 AM   #2
jaykay's Avatar
These pieces look like chain tensioner paddle wear pad (black) and vario cam wear pad (brown) fragments if they are plastic; I would make very sure they are plastic and not some strange gasket material. I would drop the oil sump cover to inspect for any debris sitting there. Do you have a cam shaft deviation reading from before you drained the oil? This may give you an idea about chain tensioner condition along with the ims bearing
From my limited experience in cutting open m96 filters, I m would say this more than normal wear and I personally would want to know the cause before continuing to run the engine. Perhaps the engine experts could chime in.
986 00S
Old 06-07-2011, 08:10 AM   #3
Thanks Jaykay. I will look up on your suggestions
Old 06-07-2011, 09:35 AM   #4
Looked at my dealer records and they said they had the IMS seal and flywheel seal replaced 1.5 years ago from the previous owner....
Worrying...
Old 06-07-2011, 09:51 AM   #5
In most cases, when an IMS bearing is heading south in a big way, you will find granular metal that is ferrous (can be picked up by a magnet), along with various other flakes and bits. I'd say that you have a tensioner pad wearing.
If this is keeping you up at night, have your cam deviation values measured at idle, if they remain steady, your IMS is still in working order. If they are bouncing around at idle, time for a retrofit..............
Old 06-07-2011, 11:50 AM   #6
Agree with previous responses. I occasionally see the same bits in my oil filiter and believe that they are from the cam chain/Variocam tensioner pads.
90K mile engine continues to run fine with no variation in cam deviation values at idle. Spent 2hrs (four 30-min sessions) on Sunday running at Auto Club Speedway near redline and the engine was happy as a clam.
Old 06-07-2011, 04:06 PM   #7
Engine Surgeon
I see chain tensioner wear material.. More specifically IMS drive chain wear pad material... And maybe some IMS bering seal material.
This WILL NOT shop up in a used oil analysis... Anything big enough to visually see seldom shows up in UOA.
Don't run it any more at all and get it into the hands of a specialist with a good boroscope, experience with M96 engine failures and some sense.
US Patent 8,992,089 &
US Patent 9,416,697
Old 06-08-2011, 12:30 AM   #8
Thanks Jake Raby Appreciate it!
