Old 06-02-2015, 10:48 AM   #21
rdass623's Avatar
by pulling up the shifter boot, you should be able to get an idea if the if there is any problem with the shifter end of the equation. if so pelican parts has a write up on removal of the center console. it may be in their article for the installation of a short throw shifter.
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 06-02-2015, 11:34 AM   #22
katanihouse@shaw.ca's Avatar
Thanks Rdass623 I'll look into that.
Boxster Blues
katanihouse@shaw.ca is offline   Reply With Quote
Old 06-02-2015, 03:02 PM   #23
seningen's Avatar
Clutch slave cylinder.
Mike
mike@lonestarrpm.com
Old 06-02-2015, 04:31 PM   #24
I had this happen on my 02 S and it was the cable end at the shifter. Removing the center console is not hard IF YOU CAN FIND ALL THE DAMN SCREWS !!! I found all of them except one it drove me nuts. It was the one by the ash tray if I remember correctly. Anyway once the console is out of the way you can clearly see the two shifter cables. Chances are you will see that one of them has fallen off the ball socket of the shifter. That means the end of the cable is worn/broken. But the ends are easily replaced. But before removing the bad end take a Sharpie pen and make reference marks , when installing the new end this will be helpful. Took me about 10 seconds to pop the new one in place and all is well. Make sure to put a little bit of grease inside the cup of the new cable end before popping it onto the ball. Good luck.
Old 06-04-2015, 07:24 AM   #25
Did yours work fine sometimes or did it not shift into gear at all? Mine would go into gear if I worked the gears starting 6th down. Now after sitting 7 months it worked fine but I never went past 2nd as I just wanted to move it back home and not get stuck out. Will look under console this weekend hopefully. Thank you for your help!!
Boxster Blues
Old 06-04-2015, 07:27 AM   #26
Mike
Lets hope it's just end broken on cable if not I'll look into this. Thanks.
Boxster Blues
Old 06-04-2015, 11:06 AM   #27
Mine worked perfect including driving it to work that morning. Came out of work, started it up and put it into reverse. Backed out of my spot and went to catch first gear and nothing. I was stuck in reverse with a limp shifter ( I hate that ! ). Shifter moved all around with no resistance at all. That's because the cable was no longer hooked up.
