Old 05-31-2011, 08:03 AM   #1
Allen K. Littlefield's Avatar
Muffler ? again
For those of you who installed a "performance" muffler I have a few questions. If you removed your rear bumper for easier access, what did you use to re-install the plastic rivets you drove out of the spoiler? Porsche parts or a substitute?
For those who installed muffler without removing the bumper was it that much of a bear or just a PITA? I will have access to a lift so I won't be crawling around underneath a car on jack stands so the job should be a bit more civil. Any extra installation tips appreciated. New muffler only weighs 18lbs so any increase in performance I suspect will come through lb loss plus quicker heat dissipation.
AKL
Old 05-31-2011, 10:22 AM   #2
i have done it both ways. if you're removing the STOCK muffler, i recommend you pull the bumper. lots of aftermarket light weight stuff is no problem, but the OEM is pretty heavy & you'll appreciate the extra room. only takes a few minutes to get the bumper off anyway.....
as for the plastic rivets? they are CHEAP from the dealer. if you want to re-use your old ones, i have seen little snippets of coat hanger used to replace the center pin in the old rivets. i.e. you insert the rivet into the hole & then insert a segment of coat hanger into the rivet itself.
insite
'99 Boxster
3.4L Conversion
Old 05-31-2011, 11:01 AM   #3
MN 986's Avatar
I replaced my OEM muffler with a FVD 'sound' version muffler that has about the same external dimensions without removing the rear bumper. I read opinions on both sides and I figured I'd take the bumper off if needed, but it went pretty smoothly leaving it on.
Good luck with the project!
MN 986 is offline   Reply With Quote
Old 05-31-2011, 12:15 PM   #4
Thanks guys...
...both suggestions very helpful. Will let you know my 'outcome'.
AKL
Old 05-31-2011, 12:29 PM   #5
Schatten-Baum-Mechaniker
I have a 2000 S, and ended up having to remove the bumper in order to get the muffler re-installed. Came off easily with the bumper on, but couldn't get the upper bolts to line up for re-installation.
I re-used the plastic rivet pieces. You just have to make sure you are careful to retrieve them after you tap them out.
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 05-31-2011, 02:32 PM   #6
ddb
www.klisstle.com
ddb's Avatar
I too removed my bumper cover (and under-assembly) to remove my OE muffler when I installed my first aftermarket muffler.
When I removed the first aftermarket muffler to replace it with my current muffler, I easily did it with the bumper cover installed.
I also re-used the original fasteners.
Old 05-31-2011, 03:37 PM   #7
Im not real sure what my fasteners were then cause they were metal and a PITA to get out. I installed mine with the bumper on. I struggled some for sure but got it done. I have some leaks around the muffler though because the bend in the "C" pipes is just slightly off. Any suggestions on the "C" pipes or should I just cut and weld them to fit. I asked a few exhaust shops in the area but they said they can't bend something that tight
http://i67.photobucket.com/albums/h3...IMAG0137-1.jpg
00 S Triple Black- Smoked lights, Tinted windows, Stainless exhaust, IwireP ipod cable, desnorkled, painted bumperettes
Jake D is offline   Reply With Quote
