Old 05-19-2011, 04:46 PM   #1
Rough running (w/Check Engine light) after jump start
I had to jump start my 2001 Boxster S after leaving the V1 "ON". Now it's missing and running very badly.
Any ideas? :dance:
Pjlew63 is offline   Reply With Quote
Old 05-19-2011, 05:03 PM   #2
dead battery = same as disconnect (memory is forgotten)
Should straighten out after 30-50miles once it relearns air-flow, mapping etc.
Good luck
Old 05-19-2011, 05:22 PM   #3
I heard about that possibility but wasn't sure how long to expect it to clear up.
If Check Eng. light should be expected as well, I should be alright.
Thanks Burg.
Old 05-19-2011, 05:40 PM   #4
Johnny Danger's Avatar
Any ideas? :dance:
Have you scanned the OBD to see what code is coming up ?
Old 05-19-2011, 07:38 PM   #5
U
Thanks Burg.
Oops, Check Engine light should not be lit. Go to local parts store and get codes read for free and post back.
Good luck :-)
Old 05-19-2011, 07:50 PM   #6
I haven't scanned the OBD.
Can I do this without special tools?
Old 05-19-2011, 09:07 PM   #7
You'll need an On Board Diagnostics (OBD-II) electronic code reader. It plugs into the colored connector (my '99 is purple) under the dash just above your left knee. Available at any auto parts store.
Alternatively, any Autozone (and some other auto parts stores) will read the code for you for free. Be sure to get the exact codes (they will start with a P followed by four numbers). Post them here and someone will give you some advice on where to go from there.
Old 05-20-2011, 04:25 AM   #8
Thank you.
Yeah it seems as if water got in the gas.
I'LL BE BACK
PJ
Old 05-22-2011, 06:11 PM   #9
Diagnostic Results
5 Codes
P0300, P0306, P0305, P0301, P0303
Mil on
Monitors
0 Inc
8 Ready
Misfire, Fuel, Comp, Catlyst, Evap, Sec Air, O2 Snsr, O2 Htr
Thank you
PJ
Old 05-24-2011, 06:47 PM   #10
Does the results of my diagnostic readout sound like it will just clear up after driving to allow for self adjustment of the mapping system?
