Old 01-28-2011, 09:40 PM   #1
Electrical plug on diff?
Hi Guys,
while fixing a fire I had from a power steering line on my 986 boxster, I found this electrical connector on the diff that has nothing connected to it. Is this correct or am I missing something???
You can see the connector just a fraction above dead center in this picture:
Any suggestions?
Sam
sparker is offline   Reply With Quote
Old 01-29-2011, 03:58 AM   #2
Reverse light?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 01-29-2011, 11:30 AM   #3
I would guess that would be up by the shifter or on the trans though? Otherwise this would only come on when you were moving in reverse, not just selected reverse?
I can test my reverse light and see if this is it anyway.
Sam
Old 01-29-2011, 11:43 AM   #4
That is the reverse light switch. You can find an excellent photo of the entire harness setup on page 34-14 in the Bentley manual.
Old 01-29-2011, 02:03 PM   #5
So I should have something plugged into it then yeah? Where abouts does the wire run, I'll try to track down where the wire ended.
Sam
