Old 07-11-2010, 02:51 PM   #1
Door speakers very quiet
I am trying to upgrade my 2002 Boxster audio system. I have a CDR-22 connected to a HAES 4x40W amp. The volume of the door speakers is really quiet, so I replaced the head unit with a Sony BT3600 (which has separate front and rear line outputs) to try and cure the problem, but unfortunately it's no better. When I fade to the rear, the volume of all speakers reduces to zero, like on the CDR-22. I have read that the door speakers sound is somehow derived from the front but as the CDR-22 has both front and rear line outputs which connect to separate pins on the amp, and the speakers are wired to separate pins on the amp (8 wires) I'm a bit confused as to why the fade function doesnt work. Does anyone think the amp is faulty? I have read on this site that the crossover is in the amp, so maybe one answer would be to get another amp which doesnt have the crossover in it? What does anyone think? Does anyone know if the 6 channel version overcomes these issues? Oh, and whilst I think about it, how the heck do you get the speaker connector off the amplifier? The outer housing slides a bit, but I've pulled it quite hard and it doesn't move. Is there a clip or something which needs to be pressed?
Confused!!
Peter
spielfreek is offline   Reply With Quote
Old 07-12-2010, 07:01 AM   #2
The door speakers are (loosely using the term) woofers only (they are just 5.25" drivers in a tuned port). There is cutoff built into the 4x40 amp (not sure at what freq exactly) which only sends low freq to the drivers in the door. They are driven (from the amp) by combining the signal for the front and rear channels. Therefore, if you fade completely to either the front or the rear, they will get no signal. Lots of info here doing a search on how to effectively upgrade the Boxster's sound system including:
-adding rear speakers (to the parcel shelf above motor)
-replacing dash speakers w/ quality coaxial speakers (or even components)
-upgrading the door speakers to 6.5" or 6.75" drivers
