03-28-2010, 08:47 AM
o2 Simulator installation
After fiddle farting around with several different after cat O2 hacks on my Boxster that were marginally effective I finally ordered and installed the Magnum O2 simulators yesterday.
A bit if history: My Box has an 04 3.6L motor, it has headers and no cats but retains the factory muffler, the after cat O2 sensors were simply attached to the underside of the car and after throwing a lot of codes I came to the conclusion that they were likely bad and therefore the normal hacks were not effective in stopping the codes. It did not make sense to buy new O2 sensors to simple hang them next to the engine so I bought the Magnum O2 simulators.
The parts: the simulators have six wires, two for the heaters, two for the signal, and a 12v power supply and ground. They are well made and mine came with a heat sink that was not shown in the pictures on their website. The electronic bits are sealed and there are two dash pots and an indicator light on the units. They run $69 per and you need two of them for a Boxster.
The Install: Soldering the wires from the original wiring harness to the part is straight forward and they provide you with shrink tubing to make the job neat. They suggest that you locate the modules as far away from the heat of the motor as possible. I ended up mounting the units on the aluminum brace that extends on a diagnal from the bottom of the motor to the rear of the wheel well. It was convenient to the plug in point for the O2 sensor and far enough away from the headers to reduce heating. I fished the power and ground wires up the back of the engine and inserted the wires into some vacuum tubing to protect it and improve the appearance and then zip tied that to the existing plumbing.
It is suggested that you power the units from a "keyed" circuit so that the power required does not draw down the battery even though the load is only 4 milliamps. Not wanting to tap into any critical circuits, I decided to power the wire off of the fuse panel from the cigar lighter circuit. I drilled a hole in one of the grommets that is under the carpet of the front motor cover. I attached the ground to the top bolt on the front motor cover which was convenient and then tucked the power wire under the edge of the center consol and ran over the drivers footwell to the fuse panel. I used a power supply that plugs in place of the fuse and moves the fuse to a 90 degree postion but preserves the fused nature of the circuit. Very handy piece of kit.
The install is very clean and the out of the box settings on the O2 Simulators worked like a charm and the codes are gone. The units did not require any further adjustment.
So if you are catless, I recommend this approach to eliminate codes once and for all.
Cheers
2001 Boxster S 3.6L, Zeintop
03-28-2010, 09:56 AM
Or, you could have a someone with a PST II/PIWIS reprogram your DME to RoW emissions standards (only US cars have four O2 sensors) and the car would be 50 state leagal with no other modifications, and the CEL would never come back for this issue................
03-28-2010, 10:11 AM
After inquiries into the ROW flash, it is about $700 cheaper to use the simulators.
03-28-2010, 03:51 PM
great work. Where did you purchase the sims from?
03-28-2010, 06:40 PM
Thanks! I ordered them from Magnumtuning.com
03-29-2010, 11:07 AM
Note: On my car, the cigar lighter is not switched. I'd guess it's the same on all Boxsters, otherwise the battery maintainer would not work.
'01 Boxster S, 51k miles
03-29-2010, 11:20 AM
It seemed the safest circut and so far so good, I have not had any battery drain but I can very easily switch circuits in the fuse box if it becomes an issue.
03-29-2010, 12:17 PM
Don't know whom you contacted, but we have had a few done by a local dealer and the price was $125-150 per...................
03-29-2010, 12:44 PM
The dealer will not touch my car it is a 3.6 transplant running x51 curves.
04-03-2010, 09:19 PM
Porsche "Purist"
The PST-2 has ROW and US codes and can flash a DME.
1987 924S. 2002 996TT. PST-2
05-08-2010, 09:05 PM
What dealer was this at?
08-26-2017, 07:18 PM
I ordered some of those from magnum tuning as well. I went to install them and now my car won't start don't know what I did wrong I figured out the relay that controls the oxygen sensors also deals with the igntion. I touched it and it was warm and none of the other ones were. Do you have any advice what to look for. I used there guide and matched up the wires. Any advice would be good. I try to do everything myself.
08-27-2017, 10:24 AM
Originally Posted by Gelbster
Thank you for describing your project. We need cheap effective solutions to CEL issues.
You're responding to s 7+ year old post.
09-22-2019, 09:33 AM
Hey, I just picked up a Boxster without Cats. I am about to order the O2 Sensor Simulators from https://www.magnumtuning.com/. I will keep you posted if this works. I did see someone had a problem above. I understand this post is older, but they should be updated as required. The more info they contain on a "searched subject" the more useful they can be.
