Old 02-14-2010, 01:20 PM   #1
Oil plug sealing washer
In the past my vendor has sent the oil filters with the aluminum gasket for the oil plug inside the filter box.
Yesterday after draining the oil (of course) I discovered that my filter was missing the aluminum gasket... and the old one was too distorted to be reused.
I went to three different auto part stores and found the same size gasket at NAPA, however I could not find aluminum or copper, the gasket I found is made of 'fiber' which I used and torqued the plug at the recommended 37 ft/lbs.
Don't have any leaks, but I am concerned about the aluminum plug becoming loose dropping the oil, any comments against using a fiber seal gasket with the aluminum plug?
Thanks, Gilles
Gilles is offline   Reply With Quote
