Old 03-10-2010, 08:17 AM   #4
Oaktown 986
Originally Posted by Gilles
In the past my vendor has sent the oil filters with the aluminum gasket for the oil plug inside the filter box.
Yesterday after draining the oil (of course) I discovered that my filter was missing the aluminum gasket... and the old one was too distorted to be reused.
I went to three different auto part stores and found the same size gasket at NAPA, however I could not find aluminum or copper, the gasket I found is made of 'fiber' which I used and torqued the plug at the recommended 37 ft/lbs.
Don't have any leaks, but I am concerned about the aluminum plug becoming loose dropping the oil, any comments against using a fiber seal gasket with the aluminum plug?
Thanks, Gilles
I currently have a "fiber" crush ring as well due to an inability to find the proper sized aluminum one nearby at a parts store. It's working great, but I will be replacing it within a couple thousand miles...
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
