Old 11-25-2009, 12:35 PM   #1
2nd Air Pump Bad.....
Who here has replaced it? I got CEL codes P0410 and P1411,both point to a bad 2nd air pump. Makes sense,it's slowly been getting loud over the years. Although I haven't ruled out valves at this point.
How much is a good price for it? Sunset Imports said it was $1k just in parts alone...but I've seen people here replace them for $600 installed.
-01' 986 S w/ 60k on it.
Old 11-25-2009, 12:59 PM   #2
After some more research I found...
http://dcauto.gotdns.com/illustration/index/489477638
$250...
Old 11-25-2009, 01:15 PM   #3
Does anyone know if I can reflash the DME to RoW spec and adjust avoid this from happening all together?
Old 11-25-2009, 02:10 PM   #4
Yes, the ROW flash ignores the secondary air injection. You can pull the pump and all of the parts off of the motor and cap the injection ports with block off plates from Porsche.
Part numbers are,
996 113 140 53
996 113 340 50
for the plates
and
996 113 233 50
996 113 213 51
for the gaskets.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 11-25-2009, 03:39 PM   #5
Good luck finding a place that does it, i tried a year back and the responce was weird, it was like listening to someone read off nerviously for emission reasons that they cannot do this for me.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 11-25-2009, 03:58 PM   #6
Part numbers are,
996 113 140 53
996 113 340 50
for the plates
and
996 113 233 50
996 113 213 51
for the gaskets.
-Todd
Would putting these plates with their gaskets be easy for a d.y.i.? I've changed my AOS before and radiator if that helps to compare my skill level.
Old 11-25-2009, 05:31 PM   #7
jumping in to say my secondary pump in my 03 986S recently went and I found one on ebay for $100 + shipping from a guy with the username mb_doctor1
( http://myworld.ebay.com/ebaymotors/mb_doctor1/ )
After changing it out it still wasn't kicking on so I checked the fuse in the rear trunk and saw that the fuse was blown. (obvious rule of thumb, check the fuses first!)
I needed to replace the pump anyway, my old one was whining a bit and I feel like it's possible that the old one died and that's what caused the fuse to blow in the first place. BUT, if you want my old one let me know, you can have it for the cost of shipping since I can't guarantee it's not dying (or already dead).
Sain0rs is offline   Reply With Quote
Old 11-25-2009, 07:20 PM   #8
Did your failing air system cause a CEL as well?
Old 11-26-2009, 04:59 AM   #9
If you can do those jobs the removal of the secondary air system will be no problem. The easiest approach is to remove the intake manifolds to gain access. Then it is just a couple of bolts. It is not necessary to remove the air system components with the ROW flash, it just cleans up the engine bay. If you have to pass a visual inspection it would be best to leave everything in place.
-Todd
Current Cars:
1989 911 Targa
1971 911T
Old 11-26-2009, 09:54 AM   #10
-Todd
So with the RoW flash the car would start w/o the 2nd air system? Or will it still start up, but the car just won't read from it?
Old 11-26-2009, 03:49 PM   #11
The ROW DME doesn't think that the air system is there so it doesn't run/use it.
-Todd
Current Cars:
1989 911 Targa
1971 911T
Old 11-28-2009, 07:49 AM   #12
Yeah it did. If I remember right the codes were p0491 and p0492.
