If you can do those jobs the removal of the secondary air system will be no problem. The easiest approach is to remove the intake manifolds to gain access. Then it is just a couple of bolts. It is not necessary to remove the air system components with the ROW flash, it just cleans up the engine bay. If you have to pass a visual inspection it would be best to leave everything in place.
-Todd
Originally Posted by blinkwatt
Would putting these plates with their gaskets be easy for a d.y.i.? I've changed my AOS before and radiator if that helps to compare my skill level.
