Originally Posted by tholyoak
If you can do those jobs the removal of the secondary air system will be no problem. The easiest approach is to remove the intake manifolds to gain access. Then it is just a couple of bolts. It is not necessary to remove the air system components with the ROW flash, it just cleans up the engine bay. If you have to pass a visual inspection it would be best to leave everything in place.
-Todd
So with the RoW flash the car would start w/o the 2nd air system? Or will it still start up, but the car just won't read from it?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
