Old 03-13-2009, 09:52 AM   #1
What's that noise?
A handfull of times now I have heard "something" behind me in the engine bay spool up and run for a while and then shut off when I kill the engine. It's definately an electric noise. It almost sounds like a fan or something. What is it that's back there that would be making that sound? It's a MY2003 Boxster.
stargate823 is offline   Reply With Quote
Old 03-13-2009, 10:06 AM   #2
tnoice's Avatar
:dance: I have heard it as well, I would be curious also.
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
Old 03-13-2009, 10:10 AM   #3
Well at least now I know that I'm not crazy. :-P
Old 03-13-2009, 10:44 AM   #4
If you hear it when you first start it up, then it automatically shuts down after a couple of minutes, it's probably the secondary air pump. Mine is pretty loud because a bearing in it is starting to go. It's a high-pitched whine.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 03-13-2009, 02:06 PM   #5
Aside from the secondary air pump which normally goes on when you first start the car and runs for about two minutes, there is also an electric fan in the engine compartment. It's located on the passenger side, towards the front, near the passenger side air vent/scoop. The next time you hear the noise, open up the engine compartment and see if the fan is spinning. IIRC, the electric fan only goes on if the engine compartment temperature goes above a certain temp.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 09-26-2009, 11:33 PM   #6
I have the same problem. High-pitched whine sound only when the engine is cold. Do I need to replace the air pump? Thanks in advance.
rmahawaii is offline   Reply With Quote
Old 10-28-2010, 02:52 PM   #7
old thread, I know.. but suffering the same noise lately...
i'm aware of the air pump that comes on during cold starts and that is working fine, but now im hearing a "whining" sound which sounds like a belt grinding into something.. (all my belts are fine and intact though)
i think i've seen that this air pump is no cheap fix... is it possible it's the exhaust electrical fan? any way to test it without having to wait for engine to heat up to temp?
stateofidleness is offline   Reply With Quote
Old 03-10-2013, 05:19 PM   #8
deptotpr's Avatar
Air pump 'whine' noise?
Searching tonight...For the first time I am hearing my air pump whine on a cold start up. Does that mean it is going bad, or is it normal?
928-to-986-to-996
Tampa Bay, Florida
deptotpr is offline   Reply With Quote
Old 03-10-2013, 05:31 PM   #9
deptotpr's Avatar
Thanks Jager
Whining sound???
928-to-986-to-996
Tampa Bay, Florida
