Originally Posted by JackG
If you hear it when you first start it up, then it automatically shuts down after a couple of minutes, it's probably the secondary air pump. Mine is pretty loud because a bearing in it is starting to go. It's a high-pitched whine.
I have the same problem. High-pitched whine sound only when the engine is cold. Do I need to replace the air pump? Thanks in advance.
