Old 11-14-2008, 05:45 PM   #1
Help. CEL won't go away after Engine Swap
I did an engine swap to a 3.4L (from a 99') after my 2002' 2.7 died.
After the mechanical was done, it drives fine, but the Check Engine Light came on. I then got the softronic software to flash my DME and it drives better, but the CEL still won't go away. I used the intake, injectors, and MAF from my boxster. Does anyone know if I should be using the ones from the 996 and is it possible?
Does anyone else know what I can do to get rid of the CEL?
Thanks,
Eric
02' Seal Grey Mettalic Boxster
www.victoreric.com
victoreric is offline   Reply With Quote
Old 11-14-2008, 06:51 PM   #2
Porsche "Purist"
Paul's Avatar
What codes are being presented?
1987 924S. 2002 996TT. PST-2
Old 11-14-2008, 11:22 PM   #3
It's reporting P1128 and P1130.
www.victoreric.com
Old 11-15-2008, 05:24 AM   #4
Send a message via AIM to dmenn
I believe those codes are for the pre-cat O2 sensors on both sides of the car. Usually both O2 sensors won't go bad at the same time. I've heard this could indicate a MAF sensor problem, but I'd search through some archives to confirm that.
2000 Boxster S, Arctic Silver, Natural Grey Leather
Factory: Aerokit I, 18" Sport Classics, Xenons, Heated Seats, Premium Sound, and more..
Upgrades: Bumper Plugs, Door Plug, Clear Sides, Clear Tails, Clear Bulbs, Painted Bumperettes, 997 Shifter, EVO Intake
dmenn is offline   Reply With Quote
Old 11-15-2008, 09:15 AM   #5
Track rat
Topless's Avatar
Your car is running lean. Most often from an intake vacuum leak, bad AOS, or bad MAF.
Old 11-15-2008, 03:44 PM   #6
Porsche "Purist"
Paul's Avatar
Can also be low fuel pressure or open evap canister purge valve.
Old 11-15-2008, 05:12 PM   #7
I've checked for intake leak and we're suspecting the MAF right now. What does AOS stand for?
Does anyone know if I need to use the 996 MAF if I did the swap? I'm using the old one from my boxster right now.
www.victoreric.com
