Old 08-26-2008, 03:39 PM   #1
Driveline slack
My drivetrain feels very loose when transitioning on and off throttle in gear. Is the front mount the one most responsible for keeping the engine/transaxle from torquing back and forth?
oversteerdawg is offline   Reply With Quote
Old 08-26-2008, 04:04 PM   #2
The engine has a mount and the transmission has 2 mounts. The engine mount is a problem with older cars as they age. The engine can contact the body and you get vibrations.
Local independent shop replace 3 engine mounts in 2 weeks.
Don't know if that is the problem, but it would be the first thing I would have checked.
Tool Pants is offline   Reply With Quote
Old 08-18-2025, 05:01 PM   #3
Uwe
Resurrecting this thread, because I have the same issue, persistent even after replacing all three mounts. We are looking at a 2000 Boxster S 6-speed manual trans car.
It goes like this: when babying the car, it is barely noticeable. when accelerating even just moderately it starts vibrating ( under load...when accelerating) most notable in first three gears. Abrupt throttle off, and back on produces a very prominent "clunk" type sound. Not really loud, but very obviously something taking up slack in both directions.
The car does not steer when this happens, and it does not seem to be coming from the axles or clutch. It's more like right under/behind the driver seat.
The engine mount was replaced very recently, together with the rubberized spacers to the left and right of the mount. Both trans mounts were done at the same time. CV axles also fresh. The entire rear suspension is brane new and has been pro- aligned. Tires are brand new. Brakes also. Not that I suspect tires and brakes to cause this thump, but just for clarification.
Weird one, this one....any thoughts ?
Uwe is offline   Reply With Quote
Old 08-23-2025, 09:23 AM   #4
The engine mount is pretty close to the drivers seat. Is it possible something wasn’t torqued enough or came loose after all the recent work that was done. I would probably start by checking the axle nut torque, Cv bolts, brake caliper bolts and then the engine mount and transmission mounts.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 08-25-2025, 09:47 AM   #5
Uwe
Thanks, Danimal!
I had the car on the lift and tried to move things by hand with a pry-bar etc, couldn't really budge anything more than expected. I wonder how much play a dual mass flywheel can come up with if it goes bad? The chassis has 160k on it, the engine 62k. I am unsure if the previous owner replaced the flywheel when the engine was replaced with a good used unit.
Be that as it may, next chance I get I will go and check all the things you had suggested. I remember tightening the axle nuts "a lot", with a breaker bar. Might not be perfectly to torque, but definitely as tight as I could get them. A re-visit and safety check is a good idea anyways.
Old 08-30-2025, 11:31 AM   #6
The front mount has a central bushing and two side pieces that reduce play further.
If those pieces are missing, it can cause clunking, looseness.
Having said that, vibration transferring to the chassis is often a symptom of racing/extra stiff mounts. The mount has a bushing to dampen the vibrations.
maxbottomtime is offline   Reply With Quote
