Old 11-22-2007, 04:10 PM   #1
Question Power Steering Leak Located
Ok i found the source of my slow power steering fluid leak, Attached is a picture of the joint where the leak is coming from. How do i fix this, is there an O-ring inside that i can replace? I already tried to tighten the joint but it was already tight and i can see that the space between the nut and the line that goes in moves alot and that whatever sealed it inside was gone or worn so there is play at the area specified in red in the picture.
If its O-rings, what size?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 11-22-2007, 06:14 PM   #2
Please tell me where that's located on the car.
I believe I've got a leak too...
wanna986 is offline   Reply With Quote
Old 11-22-2007, 10:05 PM   #3
drivers side, under the car, between the engine and passenger seat area below the car.
Carlos J Cazares
Old 11-23-2007, 03:09 AM   #4
Never seen one of those fittings apart before..... I would just open it up and see what type of seals in there.
wvicary is offline   Reply With Quote
Old 11-23-2007, 04:55 AM   #5
There is supposed to be play in that fitting if it is installed correctly. There is are o-rings that seal the fitting.
Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 11-23-2007, 08:48 PM   #6
Thanks tholyoak, Theres ALOT of play with that fitting, So much that the collar will touch the nut bolt and move away about 4 centimeters. I guess if you certain there are o-rings, Ill buy a set of o-rings and try to replace them myself.
Carlos J Cazares
