Old 11-22-2007, 04:10 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Question Power Steering Leak Located
Ok i found the source of my slow power steering fluid leak, Attached is a picture of the joint where the leak is coming from. How do i fix this, is there an O-ring inside that i can replace? I already tried to tighten the joint but it was already tight and i can see that the space between the nut and the line that goes in moves alot and that whatever sealed it inside was gone or worn so there is play at the area specified in red in the picture.
If its O-rings, what size?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
