Old 08-04-2006, 02:10 PM   #1
Question First DIY oil change...
Seeing as how the oil changes at the dealership run around $200 in Dallas/Ft. Worth, I'm going to attempt my own oil change. A couple questions.
I've read a few posts, and I'm not sure. The weather here is generally HOT, with an occasional below-freezing day in the winter. My last oil was M1 0w40 from the dealership. Should I stick with this one?
Oil filter. What parts to I need to buy? The actual filter, o-ring, AND the assembly?
Please advise.
Paul
poopoopaul is offline   Reply With Quote
Old 08-04-2006, 02:14 PM   #2
bmussatti
Posts: n/a
Here is a link to the parts:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code =OilFilterBoxsterCarreraCayenne&Category_Code=986m aint
I'd stick with the Mobil 1 0W-40
Old 08-04-2006, 02:16 PM   #3
Angry More money?
will i need the uber-fancy oil filter wrench shown below the pic of the air filters?
Old 08-04-2006, 02:17 PM   #4
bmussatti
Posts: n/a
Here is some good info on Mobil 1 products:
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1.aspx
Old 08-04-2006, 02:18 PM   #5
bmussatti
Posts: n/a
Do a search on this, you will find some good advice too!
Old 08-04-2006, 02:20 PM   #6
I have found ********************************AZ an excellent place to buy filters. www.************************************************************
No affiliation.
Norminhouston is offline   Reply With Quote
Old 08-04-2006, 06:28 PM   #7
Smile Oil wrench, and drain pan
You will need a wrench that fits the filter housing. You don't have to buy the Hazet tool, there are others that fit. You should use a torque wrench for the housing and drain plug.
Get a good oil pan. Oil comes out fast, and there is a lot of it. I just did my first one, my pan barely kept up with the flow, and it splashed a bit. Cleanup is a small price to pay for the saving and satisfaction for doing it yourself, IMO.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 08-06-2006, 04:54 AM   #8
Poopoo: Here's a good link that talks about changing your oil. Re the filter wrench/tool, you can pick up a "cup" style tool that works perfectly at Napa. Of course, you'll get lots of opinions about oil viscosity...for my $, unless you're going to drive in winter/cold, I'd go w/ the 15W50
renntech oil change thread
Also, Sunset has a sale on oil filters right now.
sunset wholesale parts
02 boxster
chopped 48 Chev pickup (under construction)
99 Harley Road King
04 Honda Element
07 Nissan Murano
rodsnhawgs is offline   Reply With Quote
Old 08-06-2006, 07:44 AM   #9
bmussatti
Posts: n/a
I don't know if 15W50 is an approved Porsche oil, maybe it is. But, I have to think that this viscosity with reduce your MPG's by 1 or 2 ticks too. Just a hunch. This viscocity is not an "energy conserving" one like 0W40 is.
Old 08-06-2006, 08:13 AM   #10
Brucelee's Avatar
Smile
M1 0w-40 is not an energy conserving oil. I think you are correct in that it will yield a very slightly lower fuel consumption than M1 15W-50. Not sure if this difference will noticiable however.
Having said that, the 15W-50 used to be an approved oil and factory fill until 0-40 came out.
I think either oil is quite fine. If it were me and I was in Texas, I would use the 15W-50 to handle the wretched heat you all get there.
Rich Belloff
Old 08-06-2006, 09:01 AM   #11
bmussatti
Posts: n/a
Richard, your're right, Mobil 1 0W40 is not an "energy conserving" blend. I think any oil above a 40 is not one. My past exprience shows a 1-2 MPG drop from a 10W30 or 5W30 vs. a 10W40 in a non-Porsche engine.
Old 08-06-2006, 10:51 AM   #12
Brucelee's Avatar
Interesting! Was the 10W-40 a synthetic oil or DINO?
Rich Belloff
Old 08-06-2006, 11:54 AM   #13
bmussatti
Posts: n/a
Not a synthetic.
Old 08-06-2006, 02:09 PM   #14
Brucelee's Avatar
Not a synthetic.
My guess is that was the major reason for the change in MPG. Synthetics generally will yield 1-2 MPG better than DINO.
Just a guess.
Rich Belloff
Old 08-07-2006, 08:36 AM   #15
Please advise.
Paul
Paul,
yes, M1 0W40 is good for that wide range.
You will need:
1- 9 quarts of oil
2- A really big catch pan to catch the old 9 quarts of oil
3- OEM or Mahle replacement OF paper cartridge
4- O-ring
5- copper crush ring for drain plug
6- filter wrench. Pennzoil "code 5" - $4 at Strauss auto, fits 3/8" ratchet
7- Some way to get the car in the air, and reasonably level. I use rhino ramps and to heck with truly level.
Tip: pre-fill the OF cannister 1/3 of the way up the side with new oil before reinstalling.
Grant
just_me is offline   Reply With Quote
Old 08-07-2006, 09:51 AM   #16
One note... buy 10 quarts of oil, not 9. The spec for filling with a complete oil drain and filter change, is 9.25 quarts. I just did a change on mine, filled it with 9.25 quarts, and its sitting exactly on full.
It was perfectly level when I drained it, and it drained for about 1/2 an hour. If you don't get all the oil out, I guess you could get by with 9 quarts.
Jack
HTML code is Off
