08-04-2006, 02:10 PM
First DIY oil change...
Seeing as how the oil changes at the dealership run around $200 in Dallas/Ft. Worth, I'm going to attempt my own oil change. A couple questions.
I've read a few posts, and I'm not sure. The weather here is generally HOT, with an occasional below-freezing day in the winter. My last oil was M1 0w40 from the dealership. Should I stick with this one?
Oil filter. What parts to I need to buy? The actual filter, o-ring, AND the assembly?
Please advise.
Paul
08-04-2006, 02:14 PM
08-04-2006, 02:16 PM
More money?
will i need the uber-fancy oil filter wrench shown below the pic of the air filters?
08-04-2006, 02:17 PM
08-04-2006, 02:18 PM
Do a search on this, you will find some good advice too!
08-04-2006, 06:28 PM
Oil wrench, and drain pan
You will need a wrench that fits the filter housing. You don't have to buy the Hazet tool, there are others that fit. You should use a torque wrench for the housing and drain plug.
Get a good oil pan. Oil comes out fast, and there is a lot of it. I just did my first one, my pan barely kept up with the flow, and it splashed a bit. Cleanup is a small price to pay for the saving and satisfaction for doing it yourself, IMO.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
08-06-2006, 04:54 AM
Poopoo: Here's a good link that talks about changing your oil. Re the filter wrench/tool, you can pick up a "cup" style tool that works perfectly at Napa. Of course, you'll get lots of opinions about oil viscosity...for my $, unless you're going to drive in winter/cold, I'd go w/ the 15W50
renntech oil change thread
Also, Sunset has a sale on oil filters right now.
sunset wholesale parts
02 boxster
chopped 48 Chev pickup (under construction)
99 Harley Road King
04 Honda Element
07 Nissan Murano
08-06-2006, 07:44 AM
I don't know if 15W50 is an approved Porsche oil, maybe it is. But, I have to think that this viscosity with reduce your MPG's by 1 or 2 ticks too. Just a hunch. This viscocity is not an "energy conserving" one like 0W40 is.
08-06-2006, 08:13 AM
M1 0w-40 is not an energy conserving oil. I think you are correct in that it will yield a very slightly lower fuel consumption than M1 15W-50. Not sure if this difference will noticiable however.
Having said that, the 15W-50 used to be an approved oil and factory fill until 0-40 came out.
I think either oil is quite fine. If it were me and I was in Texas, I would use the 15W-50 to handle the wretched heat you all get there.
Rich Belloff
08-07-2006, 08:36 AM
Please advise.
Paul
Paul,
yes, M1 0W40 is good for that wide range.
You will need:
1- 9 quarts of oil
2- A really big catch pan to catch the old 9 quarts of oil
3- OEM or Mahle replacement OF paper cartridge
4- O-ring
5- copper crush ring for drain plug
6- filter wrench. Pennzoil "code 5" - $4 at Strauss auto, fits 3/8" ratchet
7- Some way to get the car in the air, and reasonably level. I use rhino ramps and to heck with truly level.
Tip: pre-fill the OF cannister 1/3 of the way up the side with new oil before reinstalling.
Grant
08-07-2006, 09:51 AM
One note... buy 10 quarts of oil, not 9. The spec for filling with a complete oil drain and filter change, is 9.25 quarts. I just did a change on mine, filled it with 9.25 quarts, and its sitting exactly on full.
It was perfectly level when I drained it, and it drained for about 1/2 an hour. If you don't get all the oil out, I guess you could get by with 9 quarts.
Jack
HTML code is Off
