10-20-2014, 03:31 PM
04 boxster s engine swap
I swap the engine on my 04 boxster S from a 03 boxster S. The car did not start, the starter does not engage, do i need to reprogram the computer? Do i need to swap the key switch and the dme? Before i did it, i read that was a straight swap, what i am missing?
Help is need it.
Thanks to anyone that can help me out.
10-20-2014, 04:21 PM
Are you still trying to get that flooded 2004 Boxster Spyder from New Jersey running. If so what have you done to it so far.
10-20-2014, 10:27 PM
04 boxster S engine swap
I replaced the harness and installed an engine from an 03 boxster S, finally after 7 months I was ready to fire up the engine, but it did not. Everything on the electrical part is looking good, but when you turn the key the starter does not engage. I read that maybe I need to replace the switch key or reprogram the computer(DME?) to communicate with the engine. What do you think? any advice?
10-21-2014, 03:12 AM
If you have swapped either the DME or Immobilizer from one car to the other, you need some programing.
10-21-2014, 06:35 AM
The key, immobilizer and the dmd all have to be mated.
I only mention the key specifically as I know of at least two incidences folks
contacted me about this issue -- and they forgot to get the key
programmed to be accepted by the immobilizer.
Mike
mike@lonestarrpm.com
10-21-2014, 08:48 AM
If this is still that car it had sat in salt water with the battery still attached long enough that it corroded all the contact on the fuse panel. My guess is still that there isn't a good electrical or electronic component in the car. You will probably need to replace the Immobilizer, ECU, Air bag module and any other part that sat in water. That's a lot of parts it had water up to the dashboard because the entire main fuse panel had white oxidation on every contact point.
10-21-2014, 09:29 AM
Thanks everybody for the replay
I replaced everything under the seat, immobilizer and all the connectors also the air bag module, etc. Remember that all the parts are coming from the 03 so I think that the next step is to replace the ignition switch or program the key to communicate with the immobilizer. The dashboard lighted it up and most of the electrical parts are working, lights, blinking, stop, etc. The only thing that is not working right now is the doors windows, but we know that we need to replace the doors plugs and retested. I am planning to go over there on Thursday, so I will keep you posted. Any other advice that I need to keep in mind?
Thanks in advance
10-21-2014, 10:10 AM
OK you said you replaced the immobilizer. Did you get a key fob (the plastic part the key blade goes into) with the immobilizer and the ECU from the same car. Generally you can purchase all 3 from the same car which should be the same model and year as your car. In your case a 2003 or 2004 Boxster S with an automatic transmission would be the best match.
10-21-2014, 10:20 AM
Thanks in advance
Pull the blade of the old key and insert it into your 03 FOB.
I think that will work for you.
Mike
10-21-2014, 10:23 AM
Mike
Porsche 911, Cayman, Boxster (987/997) key and remote replacement as cheap as possible (and battery) - YouTube
This link shows how to remove the blade, and install it. the key fob may be different in the video but they work the same as the older style Boxster ones
10-21-2014, 10:54 AM
I can use all the parts needed from the 03 and I have both cars side by side at Mussante Motor Sports. I drove the car from RI to Connecticut, around 2 hours to go to Mussante Motors Sports, so the car was working. So if I need any part i can use it.
11-03-2014, 05:14 AM
Welcome to family.
11-03-2014, 07:06 PM
Transmission flush tool
Could somebody post a picture of the tool or machine to do a complete transmission flush for the Boxster? How much could cost? how could I check if I am low on transmission fluid?
11-22-2014, 09:18 PM
Blinking light
The car started, but now I have a blinking light on the dash board from P or Drive or any selection to 4, also the car move slowly when you hit the gas, like is in 4th gear, what I need to check for this?
11-22-2014, 09:54 PM
are you working on the car or is a mechanic from Mussante Motors Sports doing the work?
11-22-2014, 10:45 PM
I am working with a friend of mine. I towed the car from Mussante Motor Sports. They did the IMS, water pump, MAF, coil pak, etc. but the car was blinking and they explained that the car was not communicating between the engine and tranny. Also they said that they replaced the tranny oil, but when I checked it here the oil was very sluggish and had a bad smell, so I don`t think that they changed it. Also like I said, when I drained the oil, it was only less than 3 qts that came out. I replaced the filter and filled with 5 qts and it looks like it needs more, because not oil came out by the filler hole after the 5 qts when in. I am planning tomorrow to complete it. What do you think about this situation and what is your advice? I am not mechanic, but and enthusiast trying to learn and who can not afford to pay the dealer, if is something that I can avoid. I paid Mussante more than 3000.00 just for the labor.
HTML code is Off
