Old 10-21-2014, 07:48 AM   #6
jsceash
jsceash's Avatar
Originally Posted by jsceash View Post
Are you still trying to get that flooded 2004 Boxster Spyder from New Jersey running. If so what have you done to it so far.
If this is still that car it had sat in salt water with the battery still attached long enough that it corroded all the contact on the fuse panel. My guess is still that there isn't a good electrical or electronic component in the car. You will probably need to replace the Immobilizer, ECU, Air bag module and any other part that sat in water. That's a lot of parts it had water up to the dashboard because the entire main fuse panel had white oxidation on every contact point.
