Old 01-03-2018, 01:33 AM   #1
JonD's Avatar
Phone connection?
Where is the phone connection located exactly? Heard people talking about it but have no idea where it is I would like to use it...thanks
1998 Porsche Boxster
986 Arena Red, Tiptronic Base
JonD is offline   Reply With Quote
Old 01-03-2018, 02:31 AM   #2
Under the central dash, beneath the radio.
Old 01-03-2018, 03:00 AM   #3
JonD's Avatar
Thanks Jeff I'll have a look tomorrow, any pics of what the connector bit looks like?
Old 01-03-2018, 02:56 PM   #4
1999 base
Meir's Avatar
here you go.
Phone Connector behind bat wings
Old 01-03-2018, 09:27 PM   #5
JonD's Avatar
Thank You Sir/madam/poodle? Now I know what to look for
Just one more thing... would you kindly tell me the colour codes?
red-green =
green =
yellow-black =
Brown =
Thank You
Old 01-04-2018, 07:20 AM   #6
Here you go:
(updated my post in linked thread too - not sure why flickr images no longer show as they are still in my feed over there)
Good luck
"Cool Prius!"
- Nobody
Old 01-04-2018, 05:50 PM   #7
JonD's Avatar
Thanks for that
So, correct me if I'm wrong
RED-Green is 12V Always
Green is 12V Switched
Yellow&Blk is Phone Mute (whatever that means)
Brown is Negative/Ground
I'm just planning to use The Green 12V Switched with a hard wire kit for a dashCam and that's it basically.. so the cam switches on with the ignition.
And the ground wire of the kit to the Brown
Will that work guys?
Thank You
PS. Not all the pics came up in your original post with Flickr only the last one
Old 01-04-2018, 07:32 PM   #8
Porsche "Purist"
Paul's Avatar
Yes that will work.
1987 924S. 2002 996TT. PST-2
Old 01-13-2018, 05:51 PM   #9
JonD's Avatar
Well, after an exhaustive search and removal of panels, carpeting etc. I can sadly report my car doesn't have the phone connection . RoW penalty I guess.
So I am now thinking splicing into the back of the cigarette socket with T connectors.
There are 3 wires running into the back of the socket.
Brown (I assume is ground)
Red (I assume is 12V live)
Light Blue thinner wire ( I assume is for the light ring around the front of the lighter when driving lights are on?)
Anyway any other suggestions?
Bear in mind I don't want to run a line down to the fuse box.
