Old 03-15-2012, 01:12 PM   #1
zapna's Avatar
Phone Connector behind bat wings
Does anyone know where I can get the male version of this plug? It is a great source for tapping switched, unswitched, ground and telephone mute, but I cannot find a compatible connection anywhere and really don't want to have to cut off the connector.
Thanks!
zapna is offline   Reply With Quote
Old 03-15-2012, 02:00 PM   #2
you can do one of three things...
- find the male connector (BeckerAutoSound in NJ used to sell) - overpriced plus you'll still need to either splice into or add connector on other end and locate whatever you are doing w/in the wire length given (< 6" IIRC)
- take a std bullet connector Spread it open enough at the seam to trim a 'smidgen' off the barrel using wire-cutters or tin-snips. Then re-close to smaller diameter. I did this to add a hidden cig lighter outlet and worked great.
EDIT: See 1st attached image as previous flickr image now missing
- use 3m tap-splice or vampire connectors behind the plug on the wires. Sorry no pix but I did this on someone else's car and it also works great.
Here's the pin out in case you need
EDIT: See 2nd attached image as previous flickr image now missing
BOL
Last edited by Burg Boxster; 01-04-2018 at 07:22 AM. Reason: Replaced now missing flickr images...
Old 03-15-2012, 02:58 PM   #3
zapna's Avatar
I made a connector, which is better than scotchlocks, but not as good as the proper connector. I knew it was a long shot!
Thanks everyone!
Old 03-15-2012, 03:08 PM   #4
1999 base
Meir's Avatar
try this website:
Electrical
let us know the part number once you find it
Old 03-15-2012, 03:31 PM   #5
zapna's Avatar
Thanks Meir, good suggestion. Unfortunately, they carry the same stuf my FLAPS carries, and they just don't line up.
Whats worse, there are even part numbers stamped on the connector:
AMP 1-828819-1
BMW 1 378 134
But I cannot find anything on the web that provides the male counterpart! Frustrating! It would be so nice to find this part as it is in 986's and 996's for sure, maybe more and is a great place to get aux power.
Old 03-15-2012, 04:33 PM   #6
ChrisZang's Avatar
Thanks everyone!
hey, your self made "redneck-connector" looks much better than mine (No, I won't upload a photo)
Old 03-15-2012, 05:11 PM   #7
zapna's Avatar
Not my best work but gets the job done.
Old 03-15-2012, 07:04 PM   #8
ChrisZang's Avatar
one hint about mine: duct-tape ....
Old 06-21-2013, 10:27 AM   #9
Thanks everyone!
What pins did you use / where did you get them? I'm having trouble finding pins that fit! Thanks.
DK570 is offline   Reply With Quote
Old 09-10-2023, 02:57 PM   #10
Replace the OEM female with a flat 4 pole trailer wiring connector - a few bucks from H.F. or AMzn.
