Old 12-03-2016, 07:54 PM   #1
Spark Plug Tube Removal Tool
Saw this on another site
fanguy is offline   Reply With Quote
Old 12-04-2016, 02:38 AM   #2
kjc2050's Avatar
Has been discussed/debated at length.
Old 12-04-2016, 05:15 AM   #3
Good to know
Old 12-04-2016, 08:22 AM   #4
Yes. That tool works very well. Clean the tube thoughly then wrap the plug with sandpaper. The secret is not to tighten the plug too much. Tighten it a bit and pull on it. The plug should pull out. Repeat and eventually the tube will pop out.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-04-2016, 03:50 PM   #5
78F350's Avatar
~4.5" bolt, 2 nuts, 2 washers, and optional scrap of rubber tubing.
I built one after seeing this thread: Spark plug tubes
healthservices even made an animation of it in use. For me it has worked flawlessly.
Old 12-09-2016, 12:42 PM   #6
78F350 has the best practical suggestion- again !
#5 is way better than the bung in my experience.
Just be gentle
Old 12-19-2016, 08:19 AM   #7
Santa Barbara, CA
Yet another DIY Spark Tube tool.
This worked for me, just a short threaded 3/4"x 2" PVC nipple with an end cap.
I threaded it slightly into the spark tube and with a bit of wiggling out they came without removing the spark plugs first.
http://986forum.com/forums/attachments/diy-project-guides/20616d1482167501-spark-plug-tube-removal-tool-spark-tupe-tool-1.jpg
jvfante is offline   Reply With Quote
Old 05-26-2021, 07:09 PM   #8
So with the # 5 process does the washer fit the groove that the O-ring is in or does it try and catch the very back of the tube it self.? Thanks
flmont is offline   Reply With Quote
Old 05-26-2021, 07:14 PM   #9
Thanks jvfante..I will also try that process,.Maybe I was tightening the boat plug to tight but not sure how that would result in it always pulling out. Thanks !
Old 05-26-2021, 07:42 PM   #10
Very back of the tube.
Old 08-27-2023, 01:48 PM   #11
I've used all three. In order of effectiveness:
3/4" pipe with 3/4" handle
Lag bolt and washers
Boat plug
Poudre1999 is offline   Reply With Quote
Old 08-28-2023, 04:55 AM   #12
Old 12-09-2023, 02:50 PM   #13
lkchris's Avatar
Which is ...
https://www.rauchandspiegel.com/product/ultimate-porsche-986-996-spark-plug-removal-tool/
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 12-16-2023, 01:52 PM   #14
I just did mine using a 5” bolt, two washers and two nuts. I used one of the washers at the end to tug on (similar to what many here have done). They popped right out and the new tubes and o rings fit a little more snug.
Of note, all of my coil packs and tubes looked great, but I put new ones in anyway bc I don’t want to go back in there for a long time. Fitting my torque wrench for the spark plugs was challenging in some areas. Removing the engine cover helped a lot on the passenger side.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 07-30-2024, 10:18 PM   #15
Hello everyone,
I hope this question hasn't been asked before, but why are these tubes necessary at all?
Old 07-31-2024, 05:21 AM   #16
1998 Boxster Silver/Red
Originally Posted by 997_986 View Post
Hello everyone,
It's been asked a million ****************ing times. Go somewhere else build your post count, mother****************er.
1998 Porsche Boxster
Old 08-01-2024, 06:53 AM   #17
Hello everyone,
Thanks for joining the form and participating in the discussion. It’s great to get new members so that this form doesn’t continue to slowly die.
The spark plug two are needed because The boxer engine design doesn’t have a conventional valve cover / gasket. Because of that, the spark plugs tube and O-rings are needed to isolate the spark plugs.
Carlton Bale is offline   Reply With Quote
Old 08-01-2024, 10:12 PM   #18
Thank you for your kind reply! Appreciate that!
Old 08-01-2024, 10:14 PM   #19
I'm sorry if I didn't do enough searching, but at least you could have given me a hint, but you should get a good night's sleep ;-)
Old 08-02-2024, 03:25 AM   #20
I got a good sleep after having read the 16 responses/inquiries before yours... that answered your very question.
You're a newbie. General topics can be searched using the SEARCH feature. Once you've been around a while you'll find that certain subjects have been covered ad nauseum.
That you were a July newcomer... had a couple of posts... aand asked a million-times asked/answered question to the uninitiated would appear to be a scam tactic of building post counts in an effort to... wait for it.. scamming our members. That you responded with anti-AI language reveals you to be a human being. So... welcome!
Tell us what you're drivving. What are your plans with the car? What do you have to sell?
