12-03-2016, 08:54 PM
Spark Plug Tube Removal Tool
12-04-2016, 03:38 AM
Has been discussed/debated at length.
12-04-2016, 06:15 AM
Good to know
12-04-2016, 09:22 AM
Yes. That tool works very well. Clean the tube thoughly then wrap the plug with sandpaper. The secret is not to tighten the plug too much. Tighten it a bit and pull on it. The plug should pull out. Repeat and eventually the tube will pop out.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
12-04-2016, 04:50 PM
~4.5" bolt, 2 nuts, 2 washers, and optional scrap of rubber tubing.
I built one after seeing this thread: Spark plug tubes
healthservices even made an animation of it in use. For me it has worked flawlessly.
12-09-2016, 01:42 PM
78F350 has the best practical suggestion- again !
#5 is way better than the bung in my experience.
Just be gentle
05-26-2021, 08:09 PM
So with the # 5 process does the washer fit the groove that the O-ring is in or does it try and catch the very back of the tube it self.? Thanks
05-26-2021, 08:14 PM
Thanks jvfante..I will also try that process,.Maybe I was tightening the boat plug to tight but not sure how that would result in it always pulling out. Thanks !
05-26-2021, 08:42 PM
Very back of the tube.
08-27-2023, 02:48 PM
I've used all three. In order of effectiveness:
3/4" pipe with 3/4" handle
Lag bolt and washers
Boat plug
08-28-2023, 05:55 AM
12-09-2023, 03:50 PM
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
12-16-2023, 02:52 PM
I just did mine using a 5” bolt, two washers and two nuts. I used one of the washers at the end to tug on (similar to what many here have done). They popped right out and the new tubes and o rings fit a little more snug.
Of note, all of my coil packs and tubes looked great, but I put new ones in anyway bc I don’t want to go back in there for a long time. Fitting my torque wrench for the spark plugs was challenging in some areas. Removing the engine cover helped a lot on the passenger side.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
07-30-2024, 11:18 PM
Hello everyone,
I hope this question hasn't been asked before, but why are these tubes necessary at all?
07-31-2024, 06:21 AM
1998 Boxster Silver/Red
Originally Posted by 997_986
Hello everyone,
It's been asked a million ****************ing times. Go somewhere else build your post count, mother****************er.
1998 Porsche Boxster
08-01-2024, 07:53 AM
Hello everyone,
Thanks for joining the form and participating in the discussion. It’s great to get new members so that this form doesn’t continue to slowly die.
The spark plug two are needed because The boxer engine design doesn’t have a conventional valve cover / gasket. Because of that, the spark plugs tube and O-rings are needed to isolate the spark plugs.
08-01-2024, 11:12 PM
Thank you for your kind reply! Appreciate that!
08-01-2024, 11:14 PM
I'm sorry if I didn't do enough searching, but at least you could have given me a hint, but you should get a good night's sleep ;-)
08-02-2024, 04:25 AM
I got a good sleep after having read the 16 responses/inquiries before yours... that answered your very question.
You're a newbie. General topics can be searched using the SEARCH feature. Once you've been around a while you'll find that certain subjects have been covered ad nauseum.
That you were a July newcomer... had a couple of posts... aand asked a million-times asked/answered question to the uninitiated would appear to be a scam tactic of building post counts in an effort to... wait for it.. scamming our members. That you responded with anti-AI language reveals you to be a human being. So... welcome!
Tell us what you're drivving. What are your plans with the car? What do you have to sell?
