Old 11-11-2016, 06:25 AM   #1
Lpc
Bleeding clutch fluid
I do not have a pressure bleeder. Can you bleed the clutch slave cylinder, on a 1999 Boxster, with a vacuum pump? The same way you bleed a break cylinder? All the on-line info I find talks about using a power bleeder.
Lpc is offline   Reply With Quote
