Old 08-28-2017, 11:22 AM   #5
IndyPorsche
I just recently changed my slave cylinder and am now in the process of bleeding the clutch line. The problem that I am experiencing is that when I fully depressed the clutch pedal I can hear the clutch line pop out of the slave cylinder and start pouring clutch fluid all over, I then have to jump and scramble under neath the car and connect the clutch line back into the salve cylinder. Ive spent many hours researching on how to bleed the clutch and replacing the slave cylinder but none of the forums seem to address this issue or any sign that this is an issue at all. Am I doing something wrong? and I not connecting the clutch line correctly? Ive been working on this for almost two weeks and I am almost at my wits end trying to figure this out. Any help would greatly be appreciated.
I am bleeding it using a power bleeder and my slave cylinder line is attached not by a threaded nut but by a clip in system which is where its popping out of. Thanks
Porsche Boxster 2001
IndyPorsche is offline   Reply With Quote
