Old 05-14-2016, 06:10 PM   #1
removing instrument cluster to get at ignition switch
Hi guys,
Ive read all the posts about replacing the electric ignition switch on early year boxsters. Ive tried to get at it from under the dash and also thru the ac side vent. Has anyone removed the instrument cluster to get at the switch and does that help? Looks like you should be able to access the switch easily if the cluster is removed.
Thanks, Larry
022520 is offline   Reply With Quote
